Detroit locker or Marlin spool ?
Started by No Power, March 22, 2005, 07:28:05 AM
No Power
Tryin to choose one ???
Vehicle will be mostly trail (very very very little road) driven.
Detroit = $449.00
Spool = $189.00
So whatcha think ???
Thanks in advance
Roll me back over !!!
bluetoy84
Is this going in the front or rear ?
For the front go with the detroit , for the rear get the spool or save $189.00 and weld it.
No Power
Sorry bout that , it is for the rear :thumbs:
KYOTA
first choice spool or if you can do it right and want to save some $$ then weld it up. Detroits are better in front
Jack8542
 :flamer: Weld um up!!!!!!!!!!!!!!!!!!!!!!!!  I drive mine almost every day and have no problems with it.  If you only drive it mostly off road than you will end up loving your lincoln locker, if it breaks, which is a slim chance, you can just weld it again. :turtle:  :usa:
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
Skinny_Pedal
spool rear detroit front. birfields...bye bye
Im an OG
scheid6996
Its a redneck thing
"Nobody Loves Me"
mplatzer
ya you put a detroit in the front you are going to be blowing something out, birfs, sheering hubs, or even the gears. I have been running my detroit for 5 years and had no problems.
HAMMERS THE BEST TRAILS IN THE WORLD
alwayzbroken
Will a detroit locker for a standard 8" third member fit in a high pinion third member or are the carriers different?
Rockcrawlintoy
the carrier doent care if it is a high or lo pinion.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
alwayzbroken
86yota
I don't know about just re welding it if it breaks.  When mine broke it destroyed the case and the ring and pinion.  Don't get me wrong I have nothing against welding a diff, I would weld one again.  Just don't know about re welding.  Detroit lockers break also, usually when a shaft lets go.  Every thing has so much tension on it and then all of a sudden something gives way, it can be enough to destroy a locker and a ring and pinion.
89 toy
No Power
Well I think I am going with a spool from Marlin.
I like simplicity. :thumbs:
And since the spool has no moving parts it sounds
pretty simple.
Also I don't know anyone with real good welding skills :sad2:
And welding up the gears sounds kinda iffy to me anyhow.
Not to knock anyones welded up gears or anything.
Thanks
Mike
