86 4Runner 2rz swap "Chuyota" 1st build
Started by Chuyota, May 25, 2014, 11:56:15 PM
Chuyota
Quote from: toyodaaddict on July 09, 2014, 11:14:27 AM
thats scary stuff right there :yikes: maybe chevy tie rod ends arnt overkill afterall
We just got back from a wheeling trip to Red lake and Bald Mountain. Thank God it didn't break on a curve!!!
So I haven't decided on which route to take? One of these two..
megaphoneman
Awwww your pms make so much more sense.. I have steering links made out of 250 wall tubing for heim steering for a mini axle.. Worked fine on trixxie..
Blaaaahhhhhhhh
Dingman.
Shoulda just duct taped the drag link to the tie rod.  :booya:
JK  glad it broke at a decent time instead of on the freeway or wherever else.
Chuyota
Quote from: Dingman. on July 09, 2014, 10:29:03 PM
Lol. Duct tape.
Are you done with your axle set up??
Nation
Dingman.
Quote from: Chuyota on July 10, 2014, 06:12:56 PM
Lol. Duct tape.
Not yet.  Need more parts which means i need more money.
Chuyota
Look what came in the mail today!!
Check out the thickness of the pipe. That's some heavy duty stuff!!!!
megaphoneman
Haha im converting everyone to heims... U wont regret it..
That 250 wall im assuming?
Chuyota
Quote from: megaphoneman on July 29, 2014, 10:28:26 PM
I think it is.
Question- I saw that you posted on some guys forum  on how to weld the bung properly.
Any tips??
I am assuming you're heading out  MRC 13??
megaphoneman
Quote from: Chuyota on July 29, 2014, 11:25:25 PM
I think it is.
Any tips??
Yeap ill be there! And yes, you want to rosette the tube to weld it and bevel the edge of the tube as much as you can..
megaphoneman
Also check this thread out..
Good info in it..
http://www.dezertrangers.com/vb/fab-shop/159017.htm
There is one more thread when i get to the office ill look it up..
Btw i have the model 32 and have never looked back
I have 5 dies for it...
megaphoneman
here is the other thread...for converting it over to air over hydro...
http://www.dezertrangers.com/vb/fab-shop/136668-2.htm
i have bent 2in 188 wall with it and it bent it fine...
the model 32 is the better bend of the two JD ones...
but either JD32 or a Pro tools is all good. they are pretty much the same.
I converted mine over for under 200 bucks. It was easy to make a stand and get the ram from Harbor freight...
Chuyota
Quote from: megaphoneman on July 30, 2014, 09:29:24 AM
Thanks!!!!! I might be bugging you on the set up.  [emoji106]
Chuyota
Preparing the links.
I cut the drag link 33" and the other link 39"
It left half the thread inside the tube.
I did run into a problem. The heim joints are rubbing
megaphoneman
Chuyota
megaphoneman
Yeah its just more stress on the bolt.. Shorter the better what high steer arms are those?
megaphoneman
Well hydro assist wont help the rubbing.. Its just more stress cause you are using more bolt shank.. I think ur fine just use a stover nut and keep an extra bolt on board
Chuyota
Quote from: megaphoneman on August 10, 2014, 09:54:26 AM
Cool!! Thanks for the info!
Chuyota
I decided to give it a shot! I cracked open my gear box.
Installed it and it started to leak from the input shaft.
Took it apart and replaced the seal.
Part number if anyone just wants to replace the seal
Installed it, ran lines.. I used the stock pump.   It does have some delay. I'll install cooler and add more fluid. Hope it works.
Chuyota
how are you mounting that roof rack?  ive been interested in making one myself, also what kind of weight you think it will hold? looks great!!!
Chuyota
Quote from: 676869addict on August 15, 2014, 02:26:23 PM
I am not sure yet, with the wire mesh I am sure it can hold a couple bodies.  Lol. I'd say  100-200 lbs.
Chuyota
#85
Conquered "Swamp lake" id have to say it's the hardiest trail ever!!!
1985CRAWLER
Quote from: Chuyota on August 17, 2014, 10:04:15 PM
U need to hit fordyce trail, it will test yours and your rigs weaknesses :greengrin:
ive never ran any of the trails down in that area, like swamp or bald mountain or dusy, they all look fun!
Chuyota
Quote from: 1985CRAWLER on August 17, 2014, 10:17:34 PM
What so hard about it. The guys on the trial today "The Hammers" are the hardiest on the west cost.
1985CRAWLER
winch hills and water crossings when they are flowing good.
youtube search fordyce trail and u will see, rubicon is a walk in the park compared.
Chuyota
Quote from: 1985CRAWLER on August 17, 2014, 10:34:36 PM
Cool!!! Looks like I'll have to visit that trail next week after the "rubicon"
