36 inch tires
Started by No Power, March 21, 2005, 10:55:40 PM
No Power
I want to run 36x12.50R15 tires :gap:
However I just got my rims a little while ago(15x8)
Interco says to run 12.50s that my rims have to be 15x8.5 - 15x10's
Anybody here run 12.50's on an 15x8 inch rim ???
Will my sidewalls stick out to far :confused:
Thanks in advance :beerchug:
Roll me back over !!!
RUGER
i run my bfg 35" a/t's on 15x8's
that is alot of side wall i run them at a lower psi to keep them wearing even.
the swamper sidewall is stiffer but i don't see why not. on my 35x15.5 swampers i run on 15x10's.
happy trails
rich *ruger* :usa: :turtle:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
lilbuddy
From my understanding they will be fine. My friends friend has 49 Iroks on 14" wide rims and they are 21" wide...
I had 38/15.50/15 on 15x10s and i am currently running my 37s on 15x10 but was gonna use my 15x8s
RIP Kyota.... you are the man
GET IT!!!
I've seen ppl run 37s on 8s
mr4x42u
I think with a 12.50 and a 8 in wheel you will be fine,,a little squish and a tight fit will help from loosing a bead..
I ran 38x12.5's on 7" wheels and I loved it.  I never lost a bead go figure.  I wheel with a guy that has 36x13.5 iroks on a 7" wheel.  His rig is going fine like that.
ratzila
I sold a set of 44" boggers to a guy that mounted them on 15"X8" wheels. They looked awful. I used to run them on 15"X14" wheels
derek
i run my 38"x12.5"x15" tsl's on 15x8 rims.
run them at 4 lbs on the trail and have never lost a bead.
run them at like 25 lbs on the street.
derek
Hey-
Do you guys (who are running 37s or 38s on 8" wide wheels) have problems with the centers of your tires wearing out?
Because I am going to go 37s this summer but just figured I would run 10" wheels so I can get more life out of my tires on the streets.
I guess doing what derek is, at 25 lbs it would save the centers, but then the tire will run a bit warmer, consume more gas mileage, and have more sidewall roll in the corners (an actual concern of mine as my last ride was a Superchraged MR2 and I drive my truck like its a MR2).
I would like to stay with 8" so I can run less air without blowing a beed, but I also need to get some normal life out of the tires.
Thanks
No Power
Driving a toy4x4 with 37's like a MR2 sounds scary :scared:
Won't the tires buldge out real bad with 37's on 8in rims ???
I was just wonderin :dunno:
MiniSimp
You just run a lower air pressure and they will flatten back out.
KYOTA
35x12.50 on 8" rims and when I go to 38's I will run them on the 8" rims also, like whats been said the narrower rim will hold a bead better at low pressures
shad
#12
I currently have 33x13.50 LTB's on a 15x8 wheel. They will work no problem.
I ran 33x12.50's on a 15x8 on my 93 4 runner had no issues loosing a bead or anything I ran them at 12-14 psi offroad..
There's a guy on pirate running 38x14.50 TSL/SX's on a 15x8 wheel.
I think his name is TNToy on there.
here's a link to his page: http://home.off-road.com/~mithrandir/38.5/
86 Toyota 4 runner
My cardomain page
Skinny_Pedal
when i was pricing tires. big o would not even mount a 12.5 tire on an 8" rim. les schwab and discount both swore by the 8" and told me not to get 10" wheels
Im an OG
Bob Garrett
The height of the tire (35-38") won't have much effect on the wear patterns, unless you try to drive it like a sports car. I've been running a set of 35x12.50 MTRs on an 8" rim on an 80 series LC for about 35k mi with no uneven wear. Just rotate every 3-4k and you should be fine.
Bob
Bob Garrett
95 FZJ80
83 Mini Truck
My friend ran 37 mtr's with 15x8's.  It would ware the same as others.  It looked cool.  I like the look of 15x8's rather then 15x10's.
