Author Topic: 84' 22r Emissions control module .. Basic OHV setup  (Read 2009 times)
lostbuckaroo
  • Turtle Points: 44
  • Member since Jan '14
« on: Apr 18, 2014, 09:47:08 AM »
Well I've done a bunch of searching and research... My setup will be a 20r/22r combo engine to run on propane. It appears as if my California 84' has this "Emissions Control Module"... I've done some searching on this and some guys say rip it out... and everything will run fine with out it... I'm not interested in ripping it out however there will be several plugs on the wiring harness that won't be used. I'm going to run as basic a setup as possible.
PCV Valve, Vacuum advance for the dist..  Factory oil pressure sending unit, and factory water temp gauge... that's it... other than factory connections for the ignition and charging systems.. That's all I will be using of the factory harness... Question is.. will everything still run fine?
It looks as if this truck originally came with an O2 sensor in the manifold as well... ? I'm planning on running the OE 20r Exhaust manifold till I get some more $$$ For a header.
Any help/opinions/experience would be much appreciated. Thank you.
first question, where are you??  this impacts alot.
second, unless you dont have anything else dont run a 20R exhaust, run a 22R stock manifold.  it flows better and will bolt right up.
 propane will run great with a high compression ratio. but you want about a 325 cfm intake so what are you using for a "carb" with the propane setup??
lostbuckaroo [OP]
  • Turtle Points: 44
I'm in california, the truck will be strictly off-road. So I have no emissions limitations. I've got the stock 20r intake bolted up..LCE adapter for the 22r carb base as per the GotPropane setup.  I do have what I think is a stock 22r exhaust manifold.. but it has an 02 sensor on it...?
« Last Edit: Apr 24, 2014, 10:16:45 AM by lostbuckaroo »
ok, that looks good. if its never going to be smogged i would just wrap all that wiring up and zip tie it together so if you ever sold it or wanted to road it again you could.
yes, pull that 20R exhaust and install the 22R exhaust, see if you can find the twin tube one that runs down to about the cat area.  these allow more flow and give a little more torque.
lostbuckaroo [OP]
  • Turtle Points: 44
Got it thank you for your help.
Last post Sep 25, 2008, 11:29:08 AM
by THE ROCK
Last post Jul 10, 2011, 09:01:27 AM
by bslh8tr
Last post Jan 16, 2012, 06:25:53 PM
by lone walker
Last post Sep 21, 2012, 08:10:15 AM
by lone walker
Last post Dec 30, 2019, 03:37:04 AM
by Gnarly4X
