Jul 03, 2024, 04:59:10 AM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Newbie Questions
(Moderators:
*FFC*
lilbuddy
Topic:
what is this ???
Pages: [
1
Go Down
Print
Author
Topic: what is this ??? (Read 1194 times)
mudthumper401
Rock Crawl'n
Turtle Points: 20
Member since Oct '13
Crawling with Marlin
what is this ???
on:
Mar 24, 2014, 11:34:30 AM »
so theirs a little collector were my brake lines go to and then to my rear end and there is a bar type thing that runs from it to my rear axle any body have any idea what it is and do i need it ?
Logged
madhunt
Crawler Guru
Turtle Points: 52
Member since Apr '06
Re: what is this ???
Reply #1
on:
Mar 24, 2014, 11:59:01 AM »
lspv valve its a load sensing valve to adjust the rear brake pressure
Logged
HIGH AND TIGHT OFFROAD
mudmaster
The 2.5K Group
Turtle Points: 3715
Member since Feb '05
Reply #2
on:
Mar 24, 2014, 12:17:26 PM »
Yup, it's the LSPV. Is your rig lifted?
Logged
Time to go wheelin!
mudthumper401
[OP]
Rock Crawl'n
Turtle Points: 20
Reply #3
on:
Mar 24, 2014, 12:18:08 PM »
is there away to by pass it ? reason why is when im crawling i can fill it catch my axle and to let my rear left side flex all the way
Logged
mudthumper401
[OP]
Rock Crawl'n
Turtle Points: 20
Reply #4
on:
Mar 24, 2014, 12:19:07 PM »
yes have 4 inch lift
Logged
mudmaster
The 2.5K Group
Turtle Points: 3715
Reply #5
on:
Mar 24, 2014, 02:58:04 PM »
Yes there is:
http://www.davezoffroadperformance.com/store/suspension/brakes/adjustable-brake-proportion-valve.html
Or build your own setup.
Logged
Time to go wheelin!
Prismo
The 1K Club
Turtle Points: 8403
Member since Oct '03
Living in the green house
Reply #6
on:
Mar 24, 2014, 04:01:20 PM »
raise it toward the body 4 inches, make your own bracket. Quite simple if you do that
Logged
Bam
Rock Crawl'n
Turtle Points: -137
Member since Feb '14
Reply #7
on:
Mar 24, 2014, 05:27:34 PM »
Any real downside to just getting rid of it and running new lines? That's what I had planned to do...
Logged
mudthumper401
likes this
"Buy it, use it, break it, fix it, trash it, change it, mail, upgrade it..." - Daft Punk
Crunchy Taco
Crawler Guru
Turtle Points: 90
Member since Sep '13
Flexiest leaf sprung taco I kno
Reply #8
on:
Mar 24, 2014, 05:42:09 PM »
I got rid of it and just ran lines its been fine for years loaded down or not. The only thing good about it was it made the rear brakes more sensitive when loaded down. I still carry a half ton of scrap once and awhile and my brakes work just fine.
Logged
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock
http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Pages: [
1
Go Up
Print
Newbie Questions
(Moderators:
*FFC*
lilbuddy
Topic:
what is this ???
