Jul 26, 2024, 05:12:55 AM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Warm up your order by entering code
BURN
to save 10% OFF!
Vehicle Specific
Toyota Pickup/4Runner Tech 1979-95
(Moderators:
Cheesemaker
Willy Mammoth
Blingn
Topic:
86 22re cold start
Pages: [
1
Go Down
Print
Author
Topic: 86 22re cold start (Read 4299 times)
The Luke
Rock Crawl'n
Turtle Points: 0
Member since May '13
Crawling with Marlin
86 22re cold start
on:
Feb 15, 2014, 08:18:27 PM »
I'm chasing down a cold start problem. It takes a couple minutes to get the motor to start. After it's warmed up, it'll start instantly. I think I have it narrowed down to the cold start injector. I pulled the injector, cranked the key and it didn't spray anything at all. I put a meter on it and when the key was being cranked, it read around 4.6 volts to the sensor. Is that what it's supposed to be?
I read somewhere that 22re injectors are supposed to read between 6-12 volts. I checked the ohm's of the injector and switch according to the chilton manual. Both were good except the injector. it was supposed to read between 2-3 ohms, it read an avg. of 1.8.
Open to suggestions. Also looking for whatever parts we narrow it down to. :
Logged
helipilot77
The 1.5K Club
Turtle Points: 1018
Member since Jul '12
Seattle, WA
Re: 86 22re cold start
Reply #1
on:
Feb 16, 2014, 08:10:25 AM »
Sounds like you need to replace your cold start injector. The FSM say between 2-4 Ohms. Either way yours is still out of spec.
Here is another test you can do if you are hesitant to replace it without fully testing it.
Logged
& custom 3" S.S. dump pipe, R-151f transmission, marlin dual ultimate transfer cases w/ triple shifter, SAS, 35's
https://board.marlincrawler.com/index.php?topic=98969.0
-1984 SR5 Tercel 4wd wagon bone stock - given to my nephew
https://board.marlincrawler.com/index.php?topic=100547.0
-My front axle service write-up
http://board.marlincrawler.com/i
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #2
on:
Feb 16, 2014, 01:27:17 PM »
I just tried that. Worked flawlessly. So then its not getting signal. Can someone tell Me how many volts the cold start injector is supposed to see? If its supposed to be ~12 then I'm short. I'm only getting 4-6 at the injector
Logged
1985CRAWLER
The 1K Club
Turtle Points: 267
Member since Feb '13
Backyard Built
Reply #3
on:
Feb 16, 2014, 07:36:37 PM »
http://www.yotatech.com/f116/86-4runner-22re-cold-start-injector-time-switch-test-out-fine-244180/
Logged
emsvitil
Silver Turtle Award
Turtle Points: 7571
Member since May '07
Reply #4
on:
Feb 16, 2014, 11:42:00 PM »
The injector may be fine.
There's a timer sensor near the thermostat that completes the circuit.
The contacts break inside.
If you're frugal, you can fix them by taking them apart.....
Click on pictures for comments.
http://s957.photobucket.com/user/emsvitil/library/M20%20Toyota%20Cold%20Start%20Timer%20Fix?sort=4&page=1
Logged
Ed
SoCal
86 SR5 XtraCab
22RE W56B
31x10.50R15
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #5
on:
Feb 17, 2014, 05:57:16 AM »
Wow, thanks guys I appreciate the help. I might try rebuilding mine. Unless anybody has a good one that they'd let go of on the cheap?
Logged
OOPS
The 2.5K Group
Turtle Points: 1304
Member since May '02
Reply #6
on:
Feb 17, 2014, 04:24:06 PM »
Go to P-N-P and look at all Toyotas in your year range. Take a wrench with you that fits it. Cost $2.00, price of admission.
Logged
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #7
on:
Feb 17, 2014, 05:10:03 PM »
I went to two different pull a parts, pick a parts, whatever you call them yesterday. At the first lot, they had six pickups, I'll carb. Second lot, one pickup, it was frame and cab only. No 4runners. Two celicas, neither had motors.
Logged
helipilot77
The 1.5K Club
Turtle Points: 1018
Seattle, WA
Reply #8
on:
Feb 18, 2014, 08:18:08 PM »
Check on car-part.com for a wrecker in your area that has the part.
Logged
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #9
on:
Mar 02, 2014, 05:59:00 PM »
I tried that too. Part isn't listed. I was going to just start calling them but fiercefirstgen559 on here shipped me one. She's alive!!
Logged
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #10
on:
Mar 25, 2014, 07:01:40 AM »
Got my cold start problem fixed. But now I'm chasing what sounds like am exhaust leak.
22re auto. All new gaskets down passed the cat. You can hear it at the beginning of this video.
http://youtu.be/AMeltqIiS4I
Logged
emsvitil
Silver Turtle Award
Turtle Points: 7571
Reply #11
on:
Mar 25, 2014, 11:17:37 PM »
The downpipe where the 2 little pipes merge is known to crack and you may need to reweld it.............
Logged
Ed
SoCal
86 SR5 XtraCab
22RE W56B
31x10.50R15
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #12
on:
Apr 06, 2014, 07:41:24 PM »
You hit the nail on the head.
I picked up an lc engineering header off of craigslist. I've got it installed. But there is one bolt on the center of the front block off plate that doesn't fit and I can't figure what size that stupid bolt is supposed to be. It's also causing an exhaust leak right there. Any body know what size that bolt should be?
Logged
84Flatbed
Crawler Guru
Turtle Points: -196
Member since Jun '13
Reply #13
on:
Apr 06, 2014, 09:46:55 PM »
Quote from: The Luke on Mar 25, 2014, 07:01:40 AM
So, what was the fix?
Logged
The Luke
[OP]
Rock Crawl'n
Turtle Points: 0
Reply #14
on:
Apr 07, 2014, 03:42:28 AM »
Quote from: 84Flatbed on Apr 06, 2014, 09:46:55 PM
cold start injector timing switch.
Logged
Pages: [
1
Go Up
Print
Vehicle Specific
(Moderators:
Cheesemaker
Willy Mammoth
Blingn
Topic:
86 22re cold start
