Author Topic: dual case adapter question  (Read 1903 times)
goth
  • Member since Feb '14
« on: Feb 05, 2014, 01:02:03 PM »
I'm interested in getting the dual case adapter, but have a few questions before I order.
  1.The option of the spline count (21 or 23); If i chose the 23 count, what else do i need? I have 2 top shift cases.
  2.Whats the strength difference between the 2?
  3.What rotation have most used? 0 or 10 degree, pro's and con's of each.
Thanks,
goth
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
Re: dual case adapter question
« Reply #1 on: Feb 05, 2014, 02:07:56 PM »
1. 23 spline requires rear case 21 spline input to be changed to a marlin 23 spline input. as well as the 23 spline adapter.
2. strength difference is substantial. 23 spline is strongly recommended when using 4.70
3. 10* more clearance. stock, better driveline angle. i went with stock.
did i get that all right?
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
« Reply #2 on: Feb 05, 2014, 04:20:33 PM »
^All true, but I did 10* had issues getting the right front cv modified to get the droop I wanted. But I got the ground clr I wanted. Trade offs no wrong way on rotation, just a choice.
R.DesJardin
goth [OP]
« Reply #3 on: Feb 05, 2014, 06:25:45 PM »
thanks for your replies!
So if I go with the 23 spline adapter, I wouldn't need to upgrade the front box or the tranny input/output? or is this another option.
goth
toyodaaddict
  • Male Posts: 1,145
« Reply #4 on: Feb 05, 2014, 07:00:46 PM »
goth
thats correct, no need to mess with the transmission or front crawl box.
goth [OP]
« Reply #5 on: Feb 05, 2014, 07:19:52 PM »
cool, thanks again.
goth
Last post Mar 02, 2006, 11:08:54 PM
by toysfreak
Last post Aug 12, 2017, 08:51:37 PM
by TURBO
Last post Aug 13, 2008, 08:55:24 PM
by focushere
Last post Mar 02, 2012, 10:31:25 AM
by sacsogv
Last post Oct 01, 2012, 04:24:19 PM
by Twisted
