w56 id?
Started by Zane, January 27, 2014, 06:08:36 PM
Zane
ive searched the forums and came up empty handed on this one. i have a rebuilt w56 in my truck, but i didnt put it in. how can i tell what model it is? i know that there are a few different designs to the w56 and i was wondering how to tell what kind i have. :confused:
HogCanyonHopper
I have been wondering the same about mine because I want to order the short throw soon. It looks like the A and B models are top shift and the C, D and E models are forward shift  :headscratch:  :dunno:
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
jrock
Look at the shifter's bolt pattern. Compare that to those pictures. The W series also has another rib on the top driver side that the G series does not have. Plus, the reverse light switch is on the driver in the W and on the passenger for the G.
1985CRAWLER
well i tried comparing using the pics from marlin and it seems the top shift w56 A-B are identical on the outside(correct me if im wrong)..but this i what i found on pirate.
http://www.pirate4x4.com/forum/toyota-truck-4runner/965192-w56-question-faq.html
Originally Posted by TOYOTAPARTS  View Post
If the choice is between the W56 A or B take the B, it has better bearings.
[original post from big mike]
Actually the W56-A and W56-B both use the same identical bearings. The only difference would be for the 1989 1st gen 4Runner W56-B which features a double sealed 5th gear bearing, but it is still the same bearing as the other 85-88 W56s without the seals.
The obvious difference is the aluminum center plate, which does offer a weight saving, but we'd probably side with the cast iron W56-B version offering additional strength.
Internally, I believe the only difference between a W56-A and B is that the A uses a 10mm shoe and groove for 5th gear, whereas the B/C/D/E all use an 8mm shoe and gear.
The important changes didn't come until 10/91 when Toyota started changing bearing sizes, followed shortly thereafter with 3 piece synchros and added reverse gear brakes for the E models.
Regards,
__________________
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
My 511:1 Triple Cased and World's first 3RZ-powered 1st gen Hilux
HogCanyonHopper
well, I have a Marlin built W56HD so its an A/B/HD  :ha_ha:  :hammer: Next question:which short throw shifter do I need??? A or B  :dunno:
