front main seal
Started by wishin4atoy, March 18, 2005, 06:55:08 PM
wishin4atoy
my 22RE has been leaking oil for a while and i have to put a quart in every couple of week, people were tellin me that it is my front main seal. how hard is this to change? about how much does one cost?
CALIFORNIA CUSTOM CRAWLERS
"Its OK, ive got a brush guard"
Ferg
Cost is reasonable, difficulty is low.  Hardest part is breaking the crank pulley bolt loose.  I used a long breaker bar, pulled the coil wire, and hit the starter for just a click.  Don't be down there watching things have a tendancy to move around a bit.
After it's loose the rest is cake.
yep long handled breaker bar, 1/2 inch drive or you can take the outer pully off and use a boxed end wrench and a BFH
probably the easiest seal to change  :yupyup:
Skinny_Pedal
except for the oil pan gasket is can be a pita to stay on there. i used a we bit of grease so it wouldnt move. dont forget to get a repair sleeve for the harmonic balancer also
Im an OG
:smack:   :ack:  its not a harmonic balancer :smack:
wishin4atoy
thanks for the replies guys i hope this is the problem, im sick of having to put a quart of oil in my truck every couple of weeks
