toyota 3.0 starter differences?
Started by axled89, November 24, 2013, 09:38:28 AM
axled89
is there a differeence between automatic starters and manuel??????    or maybe the flywheels themselves cause the old one i pulled out was quiet like it should be. and the new one is loud like it is grinding a bit when in action.  and the new 3.0 motor they put in. he isn't positive about the flywheel being original it might be out of an automatic.  what could be the problem here any info. would be a great help. thanxs
i love oregon wheelin.
junya92toy
Autozone doesnt list one for either a manual or auto, so I would say they are the same?
Why dont you put in the quiet one?
ninja turtle
#2
I don't know if the tooth count is the same but autos have flex plates and manuals have flywheels.
EDIT: They both are 120 tooth so the starters should be the same but rockauto has 2 different numbers, one for manual and one for auto.
Part # 2800103 manual
Part # 2800116 auto
axled89
the old starter went dead. so we got one from auto zone. and it was loud and we ask for an xchange that there was something wrong with that one.  and the other new did it also. they also said the numbers are the same auto or manuel.   but i have heard somewhere that there is a differance between the two but i thought i had somthing to do with voltage.
junya92toy
Quote from: axled89 on November 24, 2013, 11:28:56 AM
Did you try new contacts before you got rid of the toyota starter?
OOPS
#5
There are two different starters, but they will both work on a manual. One is a bit bigger and heaver duty. Autos do not have a flywheel per say. they have a flex plate that the torque convertor bolts to which acts like the flywheel.
Took my buddy five starters from Vato Zone before he got one that worked right, Then it only lasted six months.
emsvitil
Do 3.0s use a nippondenso starter like the 22Rs?
If so, you're better off just fixing the original starter yourself......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Snowtoy
Yes, it is Denso, unit.
If you still have the original starter have it rebuilt, it may need more than just new contacts.
