dually rear end
Started by 83Yotabeast, October 24, 2013, 01:22:14 PM
83Yotabeast
just had a crazy idea, what if you were to put a dually axle on the rear of a crawler
opinions???
if parts aint flyin you aint tryin
89 runner
I think you can do that it should make it a full floater rear end. i want to do the same or just buy a full float kit.
1997 3RZ 4runner DD
1987 4runner 3RZ project
1986 4runner 22re stock
Cheesemaker
They are a b*std of an axle.  I always thought it would be cool to do a dually axle conversion.  Until you look at the bolt pattern you would need for wheels, the height, and the width of the wheels.  The bolt pattern is a 6 on 8.5 and the wheels are a 14"x6"   Basically, you would have to have some wheels custom made.  Then there is the spacing of the wheels/tires.  In order for the tires to not rub, the frame or each other, you would need two sets of spacers.
prineville
easier to just buy axles for the dually rear end. they are not that much and you can have them made for your bolt pattern.
if you swap in a fullsize dually from a chevy, I could see it being a lot more viable an option.... but the Toyota dually is all weird
83Yotabeast
i wasnt wanting to do it i just thought it would look kinda cool to see a crawler with a dually
Cheesemaker
Trail Tough did a Sammy called the "Crustacen" that had a kind of dually set up.
I've seen some full size rigs with dually setup, but not in a crawl setup.  Problem is the fact that the sidewalls of the tires would rub and disentegrate.  Seen may rigs with duallys run tires to wide and they would eat there sidewalls up.  Yeah, it looks cool!
toyodaaddict
theres a pretty cool scoutll that runs around town with a dually rear. its on 35-36's? it would sure suck come time to buy tires.
