more flex out of my rear
Started by 88sasturbotoy, July 31, 2013, 03:19:30 AM
88sasturbotoy
lookin to gain some more flex out of my rear heres the 2 options i could come up with cause im tryin to keep costs low so option 1 would be better just dont know if i should just go all in so here goes
option 1:
take my rear springs and move them inward like they do the ftoys and make then 28 or 29 inches wide same as the front and get creeper joints for the shackles to sit in....i wanna do this cause im tired of my rear tire lifting....i dont know if doing those mods would help and give me more rear flex or if i should do
option 2:
four link the rear.....and if i opt to 4 link the rear could i get some info on some good ways to do it where to mount the links what angles to run the links from someone who has done a rear 4 link before
any info would help im running long travel rear leafs but they dont flex as much as i want so any info would be a big help
thanks guys
88 xtra cab pickup solid axle swapped 5spd swapped 4.7 swap turbo 15psi swapped = rowdy
pumkin toy
inboard the springs F-toy style.  it will be much cheaper than 4 link and it makes a huge difference in how it flexes.  my dads 81 pickup has inboard rear springs and it works very well
97 4runner Limited
88sasturbotoy
Anyone else interested in shedding some light on this topic......inboard it or four link it
sparkys83yota
I have never seen springs moved inward. I got more flex by making my rear wider w spacers and mounting my shocks like /\. I am running all pro springs and I need to start cutting body panels to clear my 37's.  I am curious about moving the springs inward.  I got a buddy who just linked his rig. Insane flex but he spent a lot of money.
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
MRHilux87
If you daily drive it inboarded springs can be wobbly or unstable, esp with creeper joints. No saying it cant work well, but each spring doesn't isolate the movement of each tire as much.
Im working on a four link now... It doesn't cost a fortune, but its more than springs.  And you have to be a decent fabricator or be willing to spend some time reading and learning if you want it to work right.  From what I can tell..
Just my .2 cents.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
pumkin toy
Quote from: MRHilux87 on August 04, 2013, 10:10:36 PM
Just my .2 cents.
if you inboard the springs and then put your shocks on the outside of the springs as vertical as possible, it wont be unstable.  my dads truck handles like a normal truck on the highway with inboarded springs.  But he is not using the creeper joints either. I wouldn't use those if it is going to be daily driven.
97 4runner Limited
88sasturbotoy
my rig is trails only truck i got long travel leafs in the rear relocted shocks to top of axle and they are pointed inward my buddy was just thinkin if i inboarded them i would have more chance to roll it would become unstable so i didnt know if anyone has done the inboarding and ran into this problem 4 link wouldnt cost to much but it would take me a while to do once the winter hits the truck is being torn down and gone over so i was gonna redo my suspension too......i am a good fabricator but i dont completely understand the 4 link angles and all that id def have to do some reading just figured since i already have the springs i would try the inboard first since it would be cheaper and if i didnt like it i can always 4 link it later
88sasturbotoy
oh tires im running are 36 1250 15 super swamper tsl bias ply and it does look like theres going to be clearance issues i just got the tires and havent flexed the truck with em yet
pumkin toy
if you mount a set of good quality shocks (like the pressurized bilsteins) on the outside of the leaf springs after doing the inboard, its not going to feel unstable.  if the shocks are mounted in a proper vertical position and not like /\, then they will help stabilize the vehicle like shocks are supposed to do!
97 4runner Limited
