Knuckel service torque specs for 84 front end
Started by 4GuNYoDaHiCal, March 14, 2005, 07:54:46 AM
4GuNYoDaHiCal
I looked on alldata and could not find any torque specs for an 84 front end. Pulled up a diagram but I don't need that. Checked on marlin search and found nothing.  Can somebody help me out?
KYOTA
 trunion pre-load wheel bearing pre-load what?
guywithuglyyota
pre-load knuckle bearings (rotating using a SST) 4.0-8.4lb
Knuckle arm bolts= 62-79ftlbs
bearing pre-load with tensiometer= 4.0-8.4lbs
Spindle mount bolts= 29-39ftlbs
bearing pre-load = 43ftlbs - spin left/right then back off then tighten 35-60INLB inch lbs! (i miss that sometimes)
check pre-load   = 6.2- 12.6 lb to turn hub using tensiometer
lock washer/lock nut= 58-72ftlbs
free wheel hub nuts= 21-25ftlbs
Brake caliper bolts= 55-75ftlbs
hope this helps   :thumbs:
scheid6996
i hate all data!! we have it in  auto tech, give me a toy manual anytime b4 i use all data!
Its a redneck thing
"Nobody Loves Me"
4GuNYoDaHiCal
4GuNYoDaHiCal
