Boxed frame models?
Started by TimberlineBryce, May 08, 2013, 12:56:52 PM
TimberlineBryce
What Toyota trucks came with a fully boxed frame?? First gen, second gen, 4wd??? Lookin for a platform for my next project, thanks...
See you at the Timberline!
HogCanyonHopper
I think the 3rd gens is where they stopped with the fully boxed frames. I have a 97 Tacoma with the open c. The boxing stops at the front hanger for the rear springs  :thumbdown:. I have a rear shackle hanger that is a lil tweeked and its causing my truck to lean on that side and causing my new Alcan springs to flex unevenly. I plan on some plating and new hangers. Anything pre-95 would be good, but am not totally sure on that. Definitely avoid the Tacoma frames  :twocents:
Snowtoy
The Tacoma was when Toyota stopped the fully boxed frame with their trucks.
jrock
What about the 2wd? Isn't it boxed up too 1995?
TimberlineBryce
Ok so all trucks and 4runners up to 95? Or just 4wd??
OOPS
Taco frames do not need that much boxing!!!!!!
Snowtoy
Quote from: TaroVr6 on May 08, 2013, 03:30:27 PM
All pre-Tacoma 2wd and 4wd trucks have fully boxed frames, and with 1st and 2nd gen Runners using the same frame as the trucks, all of them should be boxed as well, I know I haven't seen one that wasn't.
HogCanyonHopper
Quote from: OOPS on May 08, 2013, 04:12:25 PM
Yes they do. The frame will ripple and/or crack right above the rear wheel in some cases. There is alot of info out there on the Taco frames and the issues they had with being weak and rusting like heck. Taco frames suck.
http://www.ballisticfabrication.com/1998-2004-Tacoma-Extra-CAB-Frame-Boxing-Plates_p_1820.html  This is what I want to do with my Taco frame.
Sorry, TaroV6, not trying to threadjack  :hammerhead:
OOPS
IMO that is not that much boxing. I would also but some bracing inside the "C's" before I welded the plates on.
If you think that is a lot of plateing, I would wonder what you would say about boxing an old Ford or Chevy frame from the 30's to hold a SBC!!!!!!
HogCanyonHopper
The plates are meant for the extra cabs which I think had the most problems. The open C has bracing in it but it is not enough imo. Those plates finish the boxing where Toyota left off.
TimberlineBryce
TimberlineBryce
Quote from: HogCanyonHopper on May 08, 2013, 04:42:00 PM
What about regular cab Tacomas??
HogCanyonHopper
Still the same open c frame in the rear. Pre 95 frames sound like the best option for you.
