T-case popping into neutral
Started by mendoJ, April 28, 2013, 10:58:57 AM
mendoJ
Hello everybody :wave:, I im new and just joined the site, tried to find my answer but couldn't so wanted to know if I could get some help form you guys? My daily driver 84 toyota w/ mc dual cases with twin sticks on the rear case 4-link rear 3/4t dana44 with 14 bolt rear w/ 456 gears so whats going on is when im driving down the road in two wheel drive and I let off the gas the rear left 4.70 stick pops into neutral can any one tell me why and how to fix it? It just started doing it and really need to get it fixed as it is mt daily driver... thanks for all your help
84 3/4 ton toyota ~ linked , locked and caged ! ~~Mendocrawler~~
Goldrush
Try our hd shift springs that we sell That might help. Make sure no boots are interfering with the stick or binding it. Or your tunnel as well.
88sasturbotoy
That's what I would do I think its called a detent spring or something along those lines is worn out replace it with mc heavy duty spring should work just fine after that
88 xtra cab pickup solid axle swapped 5spd swapped 4.7 swap turbo 15psi swapped = rowdy
