coax cable questions
Started by amm9130, April 19, 2013, 07:50:20 AM
amm9130
Y would coiling up the extra coax cable cause a magnetic field and interference if the cable is insulated?
1994 Pickup DLX 22re 5speed 7 in lift 37 in iroks
Cheesemaker
There is some huge debates on this.  But wiring is a tricky thing.  Especially, when your dealing with frequencies.  I've heard and read most of the debates over how the length of the cable and location of your antennae is very or not very important.  The only thing I can tell you, is to get two pairs of coaxes, and a SWR meter, and test the difference.  I keep forgetting to check into this myself, but once I set things up, I hate messing with them later, until there is a issue.  And so far my 18' of cable coiled up behind the back panel behind my seat hasn't caused any issues.  But I'm not pushing any power outside of factory settings.
There is also 3 or more levels of coax too!!
amm9130
Same here. I have my cable coiled in the compartment under the extra cab seat and I can reach out pretty far. I was wondering if rewireing it would improve distance but I don't now where I would put the extra cable where it would be "far enough apart" not to cause the magnetic field.
amm9130
I have a 20 ft cable I think and used 11 ft give or take to hook it up so my coil of extra cable is not the smallest, and thats alot to reroute in the extra cab area
