TRADES ARE MORE THAN WELCOME......
1986 parts are from a 4runner.
1983 power brake booster with master cylinder --->$20.00
1983 distributor, cap, rotor, wires, coil, IC regulator, emission control box, emission control relay, vacuum switch, oil and volt meter gauge ---> GONE...
1987 Igniter (89620-14390) harness to distributor cut, pulled from working wrecked truck ---> GONE
1983 AC compressor, AC bracket, accumulator, condensor, both AC line, 1 metal line ---> $50.00
NEW TG battery box ---> $50.00 for both or $30.00 each
NEW BWD spark plug wires, New BWD cap, New BWD rotor ---> GONE....
NEW 1983 solid rotor Raybestos brake pads ---> GONE
Make Offer....
-1983 coolant and washer fluid reservoir (great shape) ---> GONE
-1986 power steering metal reservoir with power and return lines ---> GONE
-1986 ECT electrical unit (89530-35070)
-1986 Power window relay (85930-89101)
-1986 Speed control electrical unit (88240-35050)
-1986 Cruise control button with green light (two pigtail connector)
-1986 Antenna up/down switch
-1986 Normal/Power switch
-1986 Overdrive unit (89530-35090) and overdrive indicator
-1986 Deck Lamp switch
-1986 Defroster Switch
-1986 Door Control electrical unit (85980-89101)
NEW TG silicon "L" elbow coolant hose
FREE STUFF.......
-1983 carburator mounting gasket ---> GONE
-1983 steering column cover (black) ---> GONE
-1983 cluster cover (black with blue under trim) ---> GONE
-1986 cruise control box with harness/cable (located in engine bay) ---> GONE
-1983 both evap canister, smaller unit with two electrical plug (77740-35130 and 77740-35110) ---> GONE
Will ship on your dime. I'm in Fresno.
