need help
Started by builttoabuse, February 18, 2013, 10:09:47 PM
builttoabuse
I have installed  tg trunnion bearing elminator  I've tried all diffrent sized shims and diffrent combos but everytime I go to tighten steering arms down the whole knuckle won't move any ideas whaat this could be?
And mc could you please not erase my post again thanks.
toy obsessed!
Cheesemaker
Best thing I can tell you, is you have two options:
1.  Go back to OEM setup with the trunnion bearings.
OR
2.  Call Trail Gear and see what they have to say!!
builttoabuse
Quote from: Cheesemaker on February 18, 2013, 11:23:43 PM
OR
talked to tg I guess a :pokinit: ton of shims will fix it haha sounds like a hood way to fix it ???
toy obsessed!
Cheesemaker
Sounds like you need to go back to trunnion bearings and sell those for scrap metal.  I wouldn't run more than a couple shims at best.  The more shims, the more your risk having your studs break.  Is that what you want?
OR
if I had a problem with a TG part (not that THAT will ever happen) :rofl: I think maybe I would post on their forum and not Marlins since Marlin doesnt have jack rabbits to do with anything TG has,  :dunno:
builttoabuse
Quote from: Cheesemaker on February 20, 2013, 09:00:48 PM
If thers like half an inch of shims ya for sure I'll start breaking studs its just the fact that why would they make something that you have to run that many shims in
toy obsessed!
builttoabuse
I screwed up I didnt know mc sold the 25mill sterring pin theirs is so much nicer I'm bummed I didn't get mcs :slap:
toy obsessed!
builttoabuse
Quote from: 79coyotefrg on February 21, 2013, 04:18:25 PM
I posed her because I figured someone would have the tg set up and be able to help me out.
toy obsessed!
Cheesemaker
Majority of us on here will refuse to even deal with their products, including answers questions to help you out.  Yeah they got some stuff that is innovative, but most of their products is cheap copies of other true innovators, ie Marlin, and others like him.  And not just in the Toyota world, including the Suzuki, & Jeep market.
Zane
#9
i run the trunnion bearing eliminator, and i havent had any issues with it. as for shims i think i used 1 thickest and 1 thinnest on top and bottom but i cant remember for sure.
NorCalPR
Maybe the pins or the pockets aren't pressed in all the way? When you removed the races, did you file out any bumps in the bearing race pocket?
"W6FTW"
OOPS
This is just my opinion but;
If everything is set-up right you will not be breaking studs.
ARP studs
Steering arms torqued to 100-110 ft. lbs.
If you have hydro-assist, the cylinder needs to be limited to act as your steering stop. If your cylinder still has travel after the knuckles hit the stops, you will break studs. Learned that the hard way.
Maybe it is because the T.E. is designed for the TG set-up; really do not know why that would make a difference.
The TG set-up is a good set-up (some D-60's use the basically the same type of set-up) and it works, Dave from Dave'z Off-road Performance has been running one for quite a while on a rig he DD's without a problem.
Do I run one, no I run Marlin's 25 mm set-up and am quite happy with it.
NorCalPR
The problem with the tg stuff is the pin that presses into the arms is still small. I have seen that pin shear there on the regular trunnions before.
Time will tell, but I still think the 25mm is far superior. 2 years on mine and the trunnions are still new
"W6FTW"
OOPS
Quote from: NorCalPR on February 24, 2013, 11:04:41 AM
I agree, that is what I said The frist time I saw their arms!!!
builttoabuse
Thanks everyone I decided to just take that pos set up off and go back to stock
toy obsessed!
