steering leak
Started by jackedyotaaaa, March 07, 2005, 06:16:57 PM
jackedyotaaaa
hello i have a 89 ext cab v6 straight axle conv. and i have developed a power steerting leak. the fluid is coming from what seems to be a check ball of some sort. but what gets me is it only leaks when i turn to the right? the check ball is located at the top of the box right near the steering shaft. if anyone has any info please help me out.
jackedyotaaaa
I HAVE A 89 V6 EXT CAB STRAIGHT CONV ON 36'S. I HAVE DEVELOPED A POWER STEERING LEAK OUT OF WHAT SEEMS TO BE A CHECK BALL ON THE GEAR BOX. ITS UP NEAR THE STEERING SHAFT. BUT WHAT REALLY GETS ME IT ONLY LEAKS WHEN I TURN TO THE RIGHT? ANY INFO WOULD BE GREAT.
Ferg
I devloped that same problem on the Gate Keeper.  Under the adjusting nut there is a seal/washer that got thrashed from what can only be a combination of heat and excessive slop (play) in the sector shaft.
Toyota p/n is 90210-10001, cost is about $6.00
jackedyotaaaa
MAN I SURE DO THANK YOU :)
Ferg
Let me know how it goes.
jackedyotaaaa
WILL DO, SHES GOING BACK UNDER THE KNIFE!!!! MOTOR, TRANY, DUAL CASES, AND 37
ILL TRY TO GET SOME PICS:)
