1990 4wd sas conversion
Started by mxer833, January 02, 2013, 05:33:01 PM
mxer833
I am almost done building my 1990 from a 2wd daily driver into a sas'd 4wheel drive dd, the speedometer cable is alot shorter than a stock 4 wheel drive, does anyone know where to get a 16" extension
Cyberman
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
Nimyad
If you want you could just go to a junkyard and grab a 4wd speedo cable. If you reroute it a stock one will reach with dual cases.
Real easy to remove too :)
Sent from the HO KID network using Tapatalk 2
mxer833
Do I have to re route it through the same channels I know it runs along the top of the transmission and has a few mounting spots
Nimyad
Mine I just unhooked from the back 2 holders, never had a problem with it until my transfer case started destroying speedo gears lol.
