What tire Pressure do you run?
Started by MidgetMike, March 06, 2005, 10:15:57 PM
MidgetMike
I am running 30 psi front and 25 rear, what deos everyone else run on the road and what pressure have you found helps your tires last?  :dunno:
freds40
Depends on your tires. If you're running Bias tires versus radials. I had a set of boggers that I aired up to 25 psi for a trip up north. they prematurely wore down the middle from being too hard. My next set was SXs and I ran the fronts @ 12 and the rears @ 10 around town and they wore great. Bias tires tend to crown with too much air. Radials tend to stay relatively flat. If you're running radials I'd saqy anywhere from 25-35 but it all depends on the weight and distribution of your rig.
Chalk the tires and drive say 100ft. See where the chalk rubs off and where it stays. If it is heavy in the middle, add some air. If it's heavy on the sides, let out some air. Takes a while but once you get it, you'll get the most life out of your tires.
"between projects"
mudaddict
i run my bfg muds at about 30 around town!
I work At
All Pro Off Road
RUGER
i run 22psi on my 35" bfgs with 8" rims...ware pretty good.
my swamper sx i run closer to 30psi. i don't know how well these ware evenly.
word of advise...get a good gauge. it its consistantly off by a certain psi mark the gauge +/- how much its off by.
my old gauge was off by 15psi. i was wondering why i was digging in the snow so much...i was running close to 40psi(guage read 25). :mad:
happy trails
rich *ruger* :usa:  :turtle:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
IronClad
37" mt/rs  i run  12 front and 10 rear
Annihilation  Fabrication
Do you need a Hammer?
35 MTRs on 15x8..
On the road I run 30-32
mudaddict
Quote from: IronClad on March 07, 2005, 01:41:42 AM
are we talking on the street????? or on the trail?? because that is a really low psi for the street!!!
I work At
All Pro Off Road
Rockcrawlintoy
i run like 25 in the front 20 in the rear
DRew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
lilbuddy
37" MT/Rs 25 front 22 rear. Seems to be working good so far.
RIP Kyota.... you are the man
GET IT!!!
IronClad
Quote from: mudaddict on March 07, 2005, 02:38:16 PM
thats what i run on the street  and its about right for some reason.  i know its way low but it works killer and it keeps my death wobble to a minimum  due to  somewhat bent rims/no balance
heres  what it looks like..
for some reason my truck is light or somthing
You run 10-12 psi for the streets? do you only drive straight or never over 10 mph? both?
Tim (TURBO) runs like 20 psi in his 33" tsl's and I couldnt believe it. How do you guys turn corners? At 10 mph? Put some air in so you can handle the road and save gas mileage/engine life.
IronClad
I turn just fine.  and i drive  curvy roads all the time to go to the snow and such.  and ive had the truck   up to like 75 mph and it  goes great.   must be the 15x8  wheels.    Every tire  and truck is different yanno ?   my buddy  has 33" bfg's  on his 83  and he runs 25 psi on the street while i can get away with 12 in the front and 10 out back.    :headscratch:
Thats cool, its just hard to believe.. I couldnt afford tje gas bill
MidgetMike
so it sounds like I'm runnin the right pressure for road, they are 37 x 12.50 swamper SSR's
Rockhoppa
  26 psi. front and 24 psi. rear. 36 sx's on 15x10. Works for me !!
I just thought about this, at 12psi and lets say +60mph, wouldnt the side walls burn up and your tires melt???
Nope, at about 6-8 they would be toast though.
Mike D
mudaddict
i ran 20 psi for a week didnt have any problemns turning or anyhting but i did that cuz i was to lazy to air back up hadda go to work
I work At
All Pro Off Road
