Need Help!
Started by NICKTHOMAS, December 18, 2012, 07:38:52 PM
NICKTHOMAS
So i have a 1992 toyota 4x4 with a 22re. Its lifted on 35's with stock gears. I know how it runs with these tires and all I've been driving the truck now for like 2 years and had no problems. But today after getting off work it was snowing and pretty cold so i let my truck warm up for quite a while and noticed that by the time it was warm it was only idling at less than 500rpm's. Then i start going and it feels like i have 40" tires on my truck. Every gear i have to floor it to get the truck going. Just bogs till it gets to about 2500rpms
PhantomD aka Zach
I would start with the ignition system, cap/rotor/plugs/wires....
Other things to think about is the ignitor, I have had one of those go bad on me.
If you are running 35's and stock gears you would see a huge improvement in drivability if you re-geared.
3rd Gen Extra Cab, Dual Cases, E-Lockers
NICKTHOMAS
I replaced the fuel filter, cap, rotor, spark plugs, and new wires today. I started it up and it still is running like :pokinit:. I don't know what else to do. Any help?
OOPS
You need to stop throwing parts at it and start troubleshooting it.
Here is a link to the FSM for a 93, read it and troubleshoot it.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
TRACKER
did you check the timing ? sound like stretched timing chain or bad tps .
Pride - is what drive a man to do his very best even when no one is looking ..
