85 4runner gearing questions
Started by sp543, October 31, 2012, 06:34:40 PM
sp543
I want to switch out my 4.10s for 5.29s in my 85 4tunner. The front axle is stock, the rear is out of a 92 4runner. Will the 8" 4cyl r&p set fit the rear axle? And what about the setup kit? In other words, what exactly do I need for the gear swap with these axles?
Thanks
tgmaul88
just a set up kit as long as there both 4 cylinder thirds,  if your bearings are good, you only may need a spacer and some shims
