Clutch Not Disengaging?
Started by Peterbuilt84, August 23, 2012, 01:23:54 PM
Peterbuilt84
Well, another day another problem  :talkingn: Seems that I'm having an issue with my clutch. Put in a brand new clutch from Marlin and had the flywheel resurfaced a few months back (has just sat in the garage since then). Now when I push in the clutch pedal and try to put the transmission into gear it's a no go. Goes into gear fine when not running.
Checked the slave cylinder and it moves as it should, even put in another I had and that didn't help.  Thinking maybe the clutch is sticking to the flywheel not letting itself to become disengaged. Anything else that might be causing this? Is there something I can try without pulling the transmission? Any help would be appreciated.
Cheesemaker
There is an adjuster on the clutch pedal under the dash!!
Peterbuilt84
Did not know that. So should I adjust it out more?
Also figure it's a good idea to just replace the clutch master and slave cylinder now. Everything is old and rusty now anyway.
85runner_
Swapping in slaves did you bleed it? Just like brakes.
Peterbuilt84
Yep, it was bleed. Both slaves worked (had someone push the clutch while I got under the truck and looked).
85runner_
Ok now the fork the slave pushes on. Is the throw out bearing installed correctly? Not backwards and all clips in place?
Verify clutch actually is holding by turning the drive line or pushing the truck while in gear.
Peterbuilt84
Like I said in the OP I installed everything a few months back, but I'm pretty sure it was all put together correctly.
I'm also pretty sure the clutch is holding because when I torqued down the output nut on the t-case I had to have someone put a breaker bar on the crank so it wouldn't turn.
tgmaul88
I HAVE YOUR ANSWER
Put it in 5th gear and start the truck,  let out the clutch.
your clutch has seized to the flywheel,  i had my motor out for a month installed it same thing.  couldnt get it to work. put it in 5th gear  started it, let the clutch out, it broke it free,  i dont know thats was my fix
Peterbuilt84
Tried it, no go. Guess I'm going to have to pull it.
tgmaul88
Hmm, so what happens when you push the clutch in and try to start it?
Peterbuilt84
In gear? It would move.
Already pulled it. Everything still looks new.
Here you can see a light brown coloring on the clutch disk. Thinking that it rusted and stuck to the flywheel.
tgmaul88
you pulled that quick!!!!!!!!  yeah i had that problem, but  by putting it in a high gear and starting it and letting out it fixed it for me,  that could have been, was the disc hard to remove or did it just pop right out?
Peterbuilt84
I did think that would work, but for whatever reason it didn't for me.
The disc wasn't hard to remove, came right out. Hope that I fixed whatever was causing the problem. We'll see tomorrow.
Cheesemaker
Looking at your pictures, got me thinking.   :headscratch:   First of all, there isn't enough rust to cause the clutch to stick to the flywheel.  Which them led me to think about one other thing.  Which way did you install the clutch disc, because, if you mount it backwards, it won't disengage from the flywheel because of the offset.  Supposedly the side with the springs on needs to be against the flywheel.  IIRC!  I went through my build, cause I thought I had pictures, but I don't.
Peterbuilt84
All I can say is...
And Cheesemaker, the side with the springs goes toward the transmission. Checked the fsm and here.
Cheesemaker
:doh:  My mind has been in a weird/busy place for awhile.  And I was throwing out ideas.
Will you forgive me?  :cheese:
So, you got it running then?
Peterbuilt84
Yeah I forgive you  :beerchug:  Even though you scared the crap out of me for a second  :talkingn:
And yes, it is moving now. Just need to finish a couple things up before I can hit the trails :driving:
Dooner
So any idea what caused it to lock up?
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
Peterbuilt84
Not really sure. It did sit for 6+ months so that probably had something to do with it. Like I posted there was some light rust on the clutch disk.
Think I forgot to mention that I also replaced the clutch master and slave cylinder, but that still didn't help. Then I pulled the tranny.
