need help!
Started by builttoabuse, June 20, 2012, 12:17:23 PM
builttoabuse
 :yikes: why does my front shackle have a gap between the leaf and shackle????? is the rear leaf supose to have a big gap in it its a 63 incher?
toy obsessed!
Sparkplug
the upper frame tube is wider than the spring. Stock uses confer shackles to make up for this. They sell .75 thick washers for those, or you can just stack a few washer till it sits right.
IronClad
looks like the bushings are hosed too. and your rear spring is bent
Annihilation  Fabrication
Do you need a Hammer?
junya92toy
How much does it dog track? Its common in trucks,
Rockdiver
Check the center bolts on the springs. These keep the axle centered. The rear springs seem to have a spacer or shim on top of the block and between the top leaf. What is the black tape doing? on the spring next to the bolt plate .
junya92toy
Looks like to me, a ubolt flip was done, without a proper plate, that could be issues too
Rockdiver
Your right, didnt catch that, that is the plate fron the stock bottom mount instead of the flat one . I bet the center bolt doesnt even reach it .
junya92toy
And the fact its designed to center a round tube, now its flat on flat and that might make it shift a lot, being one edge is prob trying to slide into the depression for the tube to sit in
2manytoys
Sky has Daystar bushings for 63" Chev springs. They also have the correct shackle hangers and bushings. I don't think you can use Toyota size greasable bolts. The Chevs use a 1/2" and 9/16" bolt.
e-roc
looks like the second leaf of that pack broke off at the perch. i got a set that that happened too.
