92 toyota pickup
Started by patches, May 25, 2012, 11:09:32 AM
patches
the truck is worth it in the brand new parts alone. If i had another stock pickup i would be throwing this stuff under it.  $3000.
If the price is right ill let the cage go too.
Im selling it cheaper than on craigslist because at least most everyone here knows what these parts are and i dont have to sit and explain to someone that this would not be a good daily driver for their wife.  :smack:
i have reciepts for everything but the doubler, belly ban, and front d shaft.
1992 Toyota pickup- Clean title- Just put new tags on it this year.
New Centerforce Clutch Kit done in march.
Front Axle: (recently FULLY rebuilt fall of 2011-EVERYTHING was brand new.)
• Longfield 27 Spline axles, hub gears, and extra dowel pins in hubs.
• Yukon 5:29 gears, spool. Solid spacer kit and full setup kit.
• Marlin Crawler 25MM upgrade kit w/arms, all eco-seals, and Koyo wheel bearings.
• All-PRO U-Bolt flip kit & 1.5" wheel spacers
• Trussed and knuckle ball gusseted
Rear Axle:
• Yukon 5:29 gears- welded spiders.
• ALL-Pro U-Bolt flip kit.
Suspension:
• ALL-PRO FULL extreme lift kit w/ 6" springs upgraded with Johnny joints in the rear shackles.
• 14" travel Bilstiens- shock hoops need to be rehung, i lowered the truck so much that they dont fit in the front and are limited in the rear.
Drive train:
• Advanced Adapters (Atlas) transfer case doubler.
• W-56-D transmission
• Sky Manufacturing Twin-Stick Kit and really nice Belly Pan
• Balanced HD front Long Spline Driveshaft- i have gone 40mph in 4wd with no problem
Motor:
190k original motor. Still runs fine, when its warm it weak starts sometime. and never left me stranded.
• 4X Innovations motor mounts
• Doug Thorley header- flowmaster muffler. Makes for A little obnoxious exhaust but if you like it, good.
• Air tube blockoff plate
• Optima red top
• Custom battery tray
Spare Stuff:::::
4x Innovations DOM Roll Cage for 3RD Gen Single Cab (NEW STILL IN WRAPPING SPECIFICALLY FOR THIS TRUCK)
(2) 37-13.00-15 Boggers on rims 60%
(2) 37/13.5/15 old style MTR on same rims as other 15" boggers 40%
• Working steering box- these run about $250
• Knuckles for solid axle
• 4 old style drivelines- some with the weird double ujoint deal.
• 1 third member w/ good 5:29 gears and housing but bad carrier
• 1 top shift gear drive complete t-case
The front bumper is kinda loose, it rattles around and makes a lot of racket.
I might be interested in dirt bikes or STOCK 4x4 TOYOTA TRUCKS  (NO 3.0). Let me know what you have.
Erik-541-602-7550 Call Text or Email. I work from 3pm to 8 or 9pm weekdays. If i dont answer leave a message.
I don't trust anything that bleeds for 5 days and doesn't die....
patches
Thanks man. I just need cash to break a lease and get a storage unit for the summer while I'm in Alaska again.
houndhunter_14
Are you askin three or did I miss the price?
patches
norcal666
patches
