2wd tacoma with 4wd conversion parts
Started by mobil1syn, May 21, 2012, 09:11:53 PM
mobil1syn
so i got a 2wd 01 tacoma with ~290k. runs fine, body is ok. it's a work truck.
I got diamond axles setup to go under a tacoma. front came from my previous tacoma that I rolled. http://www.pirate4x4.com/forum/showthread.php?t=828976
- front is setup for a 3-link an 8.4 chunk 5.29s and a Detroit, chevy one ton steering, longs etc. all the good stuff. 66" wide 1-1/4" heims at the axle, big bushings at the frame. 2x.25 lowers. uppers are 1-1/2 .120 with 7/8" heims. have all the hardware.
- rear is full float 8.4 chunk that's 63" wide. got an ARB with a bent pinion. but I got a new gear set and master install kit to go with it. housing is bare, comes with spring perches.
- marlin crawler dual case setup mated to a v6 tacoma case with twin sticks and fror t case mount.
- have all the drivelines
- Howe steering pump w/ 3rz bracket, universal steering reservoir, flow through steering cooler and mini truck steering box.
- will also toss in some bald 315/75/17s too
build the truck or have everything to build a Toyota based buggy.
$6,254 for all of it. I'll load it all up and you drive it home. I would drive this truck cross country without hesitation. truck is in socal
call text post whatever with questions
- Chris
951-675-8224
[email protected]
shocks, springs, tuning and more
#makingcarsgofast
mobil1syn
is the price too high? im open to offers.
would like to get ride of it all in one shot. i will seriously load up EVERYTHING  truck related i own in the bed and have the keys waiting for you.
[email protected]
#makingcarsgofast
AaronB
