1 gen front axel, into a 87 4runner?
Started by inh, May 14, 2012, 12:45:31 AM
inh
i am wondering if  the front axel off a 83 toyota pickup, will fit my 87 toyota 4runner sr5?
ajordan1975
Dr Phat
No only post 86+ solid front axles will work.
...assuming you do all the appropriate cutting preparation to accommodate a solid axle really any front solid axle will work but a front Toy 8" will be the best option.
nisota
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
stihlmohawk
You definitely posted in the right section ....just remember to do you research.  There's plenty out there.
.....If you loose in life its because you lag.....
inh
No only Ford Pinto Axles fit your front. :beerchug:
toyotanner
hahaha technically it does not fit in the front but you can cut your ifs off and make it fit :thumbsup:
nisota
Oregon wheelin'
82' 2wd-4wd project
inh
#10
Quote from: toyotanner on May 14, 2012, 11:02:16 PM
well thats what ima do a solid axel swap, i just was wondering if the axel from a 1 gen pick-up will fit.. lol.. if not i'll find a 85 axel.
toyotanner
79-85 solid front axles are the same... only thing that changed is the bottom truss
inh
Quote from: toyotanner on May 15, 2012, 05:27:02 PM
aight thanks. =)
toyotanner
oh and gear ratios changed in the diff... minor differences
