As title states "partial part out" not the whole truck
I'm converting r to re motor. From a 83, all are working when pulled
Shipping will be on buyer. Local pickup: Fresno, CA
*brake booster with master cylinder - $50
*complete lock cylinder assembly including lock cylinder with 2 key (key does not pull out), hazard button, turn signal/high beam switch, wiper control - the whole 9 yard - $60
*new semi-metallic Raybestos brake pad set for solid rotor - $13
*almost complete air condition setup minus evaporator - $65
*carburator - $65
*used for almost a year, in great shape, purchased new, flywheel and clutch - $80
*coil - $10
*voltage regulator - $10
*factory oil pressure gauge - $5
*factory voltage gauge - $5
*rancho RS5115 x2 for the front (near new) - $50
*cluster - $$FREE$$ (milage not working)
NEW - Toyota ignition control module x 2 - $175 each
I WILL ADD MORE TO THIS LIST AS I CAN FIND MORE.
PM, I MIGHT HAVE WHAT YOU NEED.
Motor is gone.
