You should buy 5.29 gears and just rebuild it as normal as possible. No amount of boreing will make up for 37s and 4.10s...
Bought me a dual case transfer adapter yesterday so i'll be running dual 2.28's. Should help it out some.
it will help a LOT but are you driving this on the highway at all?? I run dual 2.28's and 5.29's with 35 PitBull's and I couldnt imagine running with 4.10's It would be such a gutless rig it would be ridiculous.
anyway. its smokes. have you run a compression test?? this will tell you if you need new valve seals or if you need new rings or both.
dont bore unless needed that way you can save the block if something happens in the future causing you to need to over bore
Nothing wrong with building the hybrid, I plan to do it myself. I guess the point that we are all trying to make though is that is doesn't matter how much you throw at your engine, if you don't have the proper gearing for your tire size the thing will be a gutless turd anyway. A hot engine is great, but if you want to enjoy it regear too...
Yeah I know what point your trying to make and I understand it. Just thought about boring it while I had it took apart. I'm doing what I can as I can afford them. Going with the dual 2.28 cases because it is cheaper and you get lower gearing that just using a single 4.7 case. 5.29's are going to be put in after I tear down the motor and get that problem fixed first. Only reason i'm running the 37's is because I got a pretty good deal on them(37x13R15 with 80% tread with wheels for $600)
that was a GREAT dealfind a good machine shop. like who the local racers (dirt track, drag) use and take your block and crank to them. and have them do whats NEEDED. you might not need but .010 over bore. just dont have it bored over .040 because after that pistons get very expensive. like $100 EACH instead of $80 a set.you can more than likely use the rockers in your current engine but have the wear pads refurbished.
btw HOWDIE NEIGHBOR I'm from Arkansas
Good advise there, That is what I would do. I am gonna be building a 22r/20r hybrid myself soon, gonna try and run it with a chevy TBI unit on it.Where abouts is Sunbright Tn? I am in Richmond Ky.
northwest of Knoxville if I recall.
I'm an hour south of the Superlift ORV Park in HotSprings
Nice......I am just south of Lex on I 75, Ya live just about right next door. Little over an hour north of Tellico an about an hour from Harlan and Black mountain .
looks like rear spring up front. very flat rear springs I might add yea those round ubolts need to go before you kill yourself but when you get the motor in we can walk you through getting it safe and functional.OH, look at the drivers door jamb and see what the "Manufactured date" is.anything after 8-83 would have been the "new body style" for 84.
It looks like a great rig that just needs a little.... a lot of TLC.. Nothing wrong with that makes for good times. FYI i think your front boomerang shackles are upside down. looks like if you flipped them they would clear body mounts.
Started by pro86 Engine
Started by Jared « 1 2 3 » Engine
Started by kneedownnate Engine
Started by 907yota Toyota Pickup/4Runner Tech 1979-95
Started by tech201 Engine
