[AR] 1979 Toyota Pickup Crawler
Started by YotaJosh, January 27, 2012, 11:34:36 AM
YotaJosh
Sold!
Located in Little Rock, Arkansas
$5700
Winch and fairlead/Hi-Lift Jack/TEQ shift knob not included.
Body:
82 Cab/Bed
Some dents
Some rust in passenger floorboard (driverside has been fixed).
Bed is rust free (except some surface rust here and there)
~226,000 miles on body/frame.
FJ80 larger bore master cylinder
Engine:
20R (unknown mileage)
Header (new Pacesetter) with Remflex gasket.
Magnaflow cat converter and muffler.
Custom GM TBI fuel injection conversion - tuned for the 20R
Compression is 120-130 across all 4
Uses some oil - rings are worn
Rear main leaks when it hasn't been driven in a while.
Recent head gasket and head job (~4000 miles on job).
New timing chain
New radiator
Optima red top battery
GM CS130 alternator swap
Runs great for it's age. Still has decent power for a stock engine.
Front Axle:
83 Housing
Trail Gear armor/trusses
Modified for Elocker
Toyota Elocker with 5.29 Nitro gears
Marlin Crawler Elocker Motor guard
Longfield 30 spline axles
Longfield hub gears in stock Aisin hubs
ARP hub studs
ARP/Trail Gear steering studs
Marlin Crawler high steer/IFS Toyota steering box
1.25" Wheel spacers
IFS Calipers and Land Cruiser vented rotors
Stainless extended brake lines.
Rear Axle:
IFS width housing from a 92 truck
Trail Gear diff armor
Toyota Elocker with 5.29 Trail-Gear gears
Stock brakes and axles
Working Ebrake
Front Suspension:
All Pro 3" leaf springs
Davez Off Road "No Death Wobble" shackles
Marlin Crawler Ubolt flip kit
11" travel Pro Comp ES9000 shocks
Marlin Crawler front spring hanger
Marlin Crawler shock hoops
Rear Suspension:
Ford F150 57" leaf springs with extra 2.5" add-a-leaf added
Ruff Stuff Ubolt flip kit
Marlin Crawler shackles
Datin Fab front spring hangers
Bilstien 10" 5125 shocks
Transmission/Transfer Case:
W56B transmission from 85 truck (countershaft bearing replaced recently)
Dual case crawl box setup using MC07-R10 Marlin Crawler adapter.
Rear transfer case is a 79 model, with the slightly stronger input shaft.
Both cases have stock 2.28 gearing.
Front Range Off Road crossmember and skidplate
All-Pro Long Travel driveshaft kit for front
CV style driveshafts front and rear. Rear is balanced. Front runs up to 50 MPH.
Armor:
Marlin Crawler rear bumper.
Custom fabbed front bumper for Warn 8274 and Hawse fairlead
Custom fabbed rock sliders. Welded to frame, not bolted.
Wheels/Tires:
15x8 ProComp RockCrawler steel wheels. 3.5" backspacing.
36x13.50x15 Super Swamper IROKs - worn and custom grooved.
Matching spare tire on similar steel wheel.
Interior:
Bucket seats from 95 Camry.
Switches for front and rear Elockers. In cab winch controls.
SR5 gauges (tach, oil, volt)
Accessories/Extra:
Diamond plate toolbox with cool stickers on the lid underside
IPF 968 lights on front bumper
Tuffy Tiedown Rails in bed
Hi Lift mount (custom fab by me)
Quick removable doors (hinge mods by me)
Items that I'd like to keep, but for extra $$ you can have them with the truck:
Warn 8274 winch with 125' of synthetic line and a new Warn motor
Aluminum hawse fairlead
60" Hi Lift jack
About the truck:
Built from a cab/frame into a hardcore rock crawler that is still street legal and can carry you to the trail on the highway. This truck has ran nearly all the 4 rated trails at Superlift in Hot Springs and Barnwell Mountain in Gilmer, Tx (and some of the 5 rated trails too!).
My future plans were:
Hydro assist
New 37" tires (current ones don't balance well and wobble some)
Shave the axle housings and remove the drain plugs.
Tube doors or half doors
22R short block combined with my 20R head. Plus my EFI setup and a new performance camshaft. (can include shortblock core to rebuild for full asking price)
Pictures:
Album with all pictures:
http://s1266.photobucket.com/albums/jj532/yotajosh/1979%20Toyota%20Pickup%20Crawler/
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Sparkplug
Love the spider gear shift knobs man. Bump for a sweet truck
toyotathomas
Sweet first gen man. :yesnod:  By chance do you know what size kobalt toolbox that is?
Bump for a nice rig!
YotaJosh
Quote from: Sparkplug on January 27, 2012, 11:42:20 AM
Thanks!
Quote from: toyotathomas on January 29, 2012, 03:52:06 PM
Thanks! No, I don't. I bought it used from someone who had it on their newer Ford Ranger.
BHT12
1984 4runner. Trailgear fronts, custom backs with shackles, 36 iroks, hi steer, hybrid 20+22r motor, full exhaust, lowsy weber, power everything, rear heat, power Antena,  sr5, altimeter,  back seat eliminator, tube bumper
1981 2wd long bed parts getter. All stock, sr5
1983 Toyota Sandtana Motorhome 4x4 Stock.
waynescamo
YotaJosh
#6
Bump!
My free photobucket account is nearing it's transfer limit, so if the pictures quit working, then you can view them all in my Google+/Picasa album.
http://plus.google.com/photos/107145007282473048297/albums/5700610923989091505
BHT12
FYI  The link didnt work when i clicked it
YotaJosh
Quote from: BHT12 on February 02, 2012, 11:54:37 AM
I fixed it. Thanks for the heads up. I always forget that the Marlin forum is not vBulletin and sometimes the BB code doesn't copy over well.
90 sa-yota
90 Yota truggy 4banger dual t-cases, front linked fj80, rear t100 axle on 39 Bfg's
DD 00 Fird f250 x-cab 7.3 auto on 33's tow rig
DD 2006 yota taco prerunner
DD 82 yota 4wd on 33's play toy
Future LONG TRAVEL toy 04 taco 4 dr. Prerunner
YotaJosh
Caboose
Sweet rig, where did you get the switches for your panel?
"Who let the jeeps come?
Easy... easy..." -2 people on the CB
81 Toy Pickup SR5
http://board.marlincrawler.com/index.php?topic=35701.0
Daily Driver: 96 Dodge Ram 2nd DD/Tow Rig
YotaJosh
Quote from: Caboose on February 25, 2012, 02:47:28 PM
Thanks!
Switches came from here: http://otrattw.com/
YotaJosh
