gears
Started by will82yota, January 17, 2012, 08:42:25 PM
will82yota
i have an 82 yota straight axle with a 4 inch lift on 33s and i was wondering what gears should i put in it to make a good general off road truck and daily driver
hansi530
 would say 4.88 if ur planning on sticking with the 33s
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
will82yota
Snowtoy
4.88's will put closest to the stock set-up of 4.10's and 28" tires.  However if you are like most, you will likely want to run 35's or bigger tires down the road, so the 5.29 gear set might be a better choice.  On paper there is only about a 250rpm difference between the 4.88's and 5.29's in 5th gear(.851) at 70mph.
If you want to compare the difference in rpm's for different combinations of transmission gears-differential gears-tire size, these Drivetrain Calculators should give you most of the info needed.  The transmission gears for your transmission can be found here at Marlin's Transmission Gear Ratio Chart.
