Marlins springs
Started by guywithuglyyota, February 17, 2005, 05:18:24 PM
guywithuglyyota
Well I Orderes a skyjacker 3" lift from some really unorganized online store (4wheelparts.com) And after three weeks and a lost order Im going to cancel and go with the marlin 3" springs. Any of you guys running these yet? I know the rear springs are still new. Im confident they will do just fine considering the reputation of the other products, just looking for real world feedback.
Luke
blackdiamond
I had 4wheelparts (Tacoma, WA) install my 4.5 inch Superlift a couple of years ago.  The only problem that I had was they destroyed my rear shackles when they took them off and I ended up with extended shackles that made the truck way to high and caused vibration.  I had to find some stock shackles and install them myself.  I currently have Alcan rear springs on order, the Superlift rear springs are terribly rigid.
The Marlin springs are longer than stock and will require you to move the foward mount and the shackle mount, the Superlift springs wouldn't require this.  I opted for an Alcan spring that uses the stock locations to avoid the added install problems.  The cost is similar when you consider purchasing mounts and fabrication work.  I'm sure the Marlin springs are great quality if you are willing to do the work.
Something to consider.
Skinny_Pedal
i didnt recall moving my shackle location with my mar springs. they are uber soft. also there isnt a bunch of work to make them work. u could easily do it in a day. better flex to, stock length sucks
Im an OG
scheid6996
does mar make 4 inch springs, stock length, but move the front axle 2 inch forwerd?
Its a redneck thing
"Nobody Loves Me"
Skinny_Pedal
Im an OG
scheid6996
well wut do they make that comes close to wut i want?
Its a redneck thing
"Nobody Loves Me"
Skinny_Pedal
why do u want stock length...thats just silly :crazy:
Im an OG
blackdiamond
Everyone has different goals for their trucks.  For me it is important that I can drive my truck cross country and since I have a limited budget and lack in fabrication skill, it is best to keep things as simple as possible.  I don't plan to relocate the shock mounts, other than the lower mount for the u-bolt flip kit, so the amount of travel will be limited making long springs less important.  Right now my truck has about 2 inches of travel in the rear from full compression to full extension (Superlift rears are horrible) and it has not stopped me from going anywhere I wanted to go yet.  I think that Alcan can build me a spring pack that will give me adequate flex for my level of wheeling and they will handle better on the road.  Alcan makes a 5 inch longer spring application, but advised that I get the shorter configuration for my purposes.  Most people think that Alcan is the king of springs so I am going with his recommendation.  Yes, in general longer springs have better flex, but they are not the best option for everyone.  I will post before and after pictures once I get them installed.
