I have been searching for nearly 2 hours how and I havent foudn any solid info on what I need at all, Im not even sure where to look anymore.
I have downloaded both the 90-95 4runner FSM and the 95.5-97 Tacoma FSM off of the ttora website. I have looked through both but havent found any solid info. I need to know the pinouts for the IH1 and IH2 plugs that are in the pass kickpanel on the 90 harness and then I need the 1k2 and 1k3 (?) plugs that are also in the same spot but for the 96 tacoma 3rz harness. The wiring diagrams that are on both FSM's only show the actual wiring diagram for the ecu, and not the actual pinouts for both plugs on each harness that I need (the plugs go to the dash wiring that goes to the key switch, fuel pump circuit, starting circuit and all the gauges/dash lights.
Who knows what they are on both and/or where I can find this info?
