caliper bolt hitting the rotor? mine did that a couple times i had no washer on the bolt so it went too far and hit the rotor causing it to not move
looks like its just not seated all the way on the spindal
wrong bearing seated on the back of the hub?
ya its probably just not seated all the way on the spindle. just give it some taps or shake it on there or somthing. happens all the time
It should seat when you crank down on the spindle lock nut. But you may pull of the rotor again and see if something is up with the inside bearing before doing that... It could have been knocked a little sideways or something.
Started by Mark m. General 4WD Discussion
Started by firefighter jeepin Toyota Pickup/4Runner Tech 1979-95
Started by InsideLine209 Toyota Pickup/4Runner Tech 1979-95
Started by yoda4x4 Toyota Pickup/4Runner Tech 1979-95
Started by matthedingoduk Toyota Pickup/4Runner Tech 1979-95
