I have a 79 with the original L43 4 speed in it behind a recently rebuilt 20/22r hybrid. I am running Old Man Emu springs with the stock hangers and 5" shackles with stock driveshafts. I just picked up a used R151 turbo tranny that is complete with bellhousing, transfer case, and shifters. I would like to put the tranny in as is(and put 4.7 gears in the transfer case at some point). I have been searching a bunch about swapping to the newer 5 speed and am hoping for a little more info. 1-Tunnel clearance? I have read about the having to pound out the transmission tunnel to make the newer tranny fit. Does anyone have a pic of doing this and exactly where I need to create more room? My R151 is forward shift so the shifters should stick up in about the same location correct? I'm fine with doing some trimming, just wanted to check.
2-Crossmember? I have read that you can just spin the existing crossmember around and the 2 existing rear bolt holes line up so you just have to tap 2 new holes. Once again, anyone have any pics? I would like to eventually switch to a budbuilt crossmember but if it is easy to use the stock one for now I'll do that.
3-Clutch? I have also read that I have to run a newer clutch master cylinder and slave cylinder. Should I just get the entire clutch assembly off a newer truck? Or can I just add a slave cylinder and use my existing master and line? The R151 has the clutch fork on it. Also, my clutch and flywheel are still in good shape. Can I use them or do I need to get a different clutch?
4-Driveshafts? I know the transmission is 4" longer. Will a front d.s. out of a 84-85 (or a clearenced IFS d.s.) be the correct length? Does anyone know what this length is? With the same thought, I think a 84-88 rear d.s. from a 4runner or SB will fit. Again, do you know the length? (seems like people have driveshafts sitting around but they don't exactly know what they are out of so some measurements would help when I am looking) I don't want to have my existing d.s. modified because the front spline has a lot of play and I would have to ship them somewhere to have it done.
That is a lot of questions, but I know there are at least a few people on here who have done this exact same swap(or a W56).
Started by YOguyDa Toyota Pickup/4Runner Tech 1979-95
Started by black92se Toyota Pickup/4Runner Tech 1979-95
Started by paradisetoyota Toyota Pickup/4Runner Tech 1979-95
Started by ImmortalYota80 Parts Wanted
Started by lance808 Transmission/Clutch
