Author Topic: Inside tire wear ?  (Read 2053 times)
Slobbermouth
  • Male Posts: 221
  • Member since May '07
Inside tire wear ?
« on: Nov 29, 2011, 12:22:21 PM »
I am running 37X12.50 15 MTR's with 12 inch beadlocks 3" BS.  I am getting excessive inside wear on both fronts. I have checked the Toe ? I get about 3/16 difference front to back. When I jack the rig off the tires I do not have any excessive movement top to bottom or side to side. All of my rod ends are tight.  Any suggestions on what else to check ?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Inside tire wear ?
« Reply #1 on: Nov 29, 2011, 12:23:35 PM »
either your toes is off, your bearings are shot, or your axle is bent
dirtybird
  • Turtle Points: 3
  • Male Posts: 166
  • Member since Aug '11
« Reply #2 on: Nov 29, 2011, 10:23:30 PM »
X2.  If your sure and double sure about the items you checked you have a bent housing
Slobbermouth [OP]
  • Male Posts: 221
« Reply #3 on: Nov 30, 2011, 10:47:47 AM »
I am not hard on the rig I can not see or remember when I could have bent the tube ?   I am assuming a front end alignment shop should be able to straighten it ?  Any recommendations for alignment in the Fresno area ?
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #4 on: Nov 30, 2011, 11:02:22 AM »
it doesnt take much to bend a toyota axle and i dont think an alignment shop would be able to straighten it. Most of the time we pull them off the truck and chain them down and use a bottle jack/cutting where necessary and weld it back up
Do you need a Hammer?
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #5 on: Dec 01, 2011, 07:38:21 AM »
Bent housing... I fixed mine with a bottle jack, a log chain and a piece of railroad iron.  Came out just fine.  Then add gussets and wheel on.
– Steve McQueen
scoutrunner
  • Member since Jul '10
« Reply #6 on: Feb 05, 2012, 07:29:03 AM »
same here mine was bent when i bought it!!  i cutt the tube on the bottom half bent it bach straight the welded half cut tubing over the area to reinforce it. worked great.
Last post Jun 16, 2006, 12:19:26 PM
by 79coyotefrg
Last post Apr 11, 2008, 12:33:27 AM
by THK Matt
Last post Mar 08, 2010, 03:00:53 PM
by nwx
Last post Aug 22, 2012, 09:47:52 AM
by CruelCrawler83
Last post Jul 28, 2019, 01:14:38 PM
by Pat
