what springs should I use to build a flexy custom spring pack for the rear?
Started by NorthBayCrawler, November 15, 2011, 05:49:17 PM
NorthBayCrawler
I dont want to do Chevy springs. If I cant figure out a good combination Ill just buy all pros, I would rather not spend that much cash though.
twistedtoy92
f150's, 3rd gen rear custom pack... lots of options, what exactly are you putting springs on and how much lift?
NorthBayCrawler
1983 x-tra cab. im looking to obtain 4 inches, what would you suggest?
twistedtoy92
f150s are pretty good, throw another leaf in and adjust the rest of the height with shackle length. There are quite a few write ups on here about the f150's :beerchug:
sweetmeat
If you really want them to flex you should inboard them inside the frame. Then it really don't matter what srings you run they will flex like a mo foo. Here's what i did, 5in marlin springs inboarded
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
