sounds more like the driveshaft bolts are coming loose, or maber the slip splines on the driveshaft need greesed, my 4runner with 7" of lift uses the stock driveshaft with no vibes from angle
oh also swapped out the drivers CV joint yesterday, phil you would have been proud, only took us 6 hours and we only almost killed ourselves twice
only 6 hrs, niceabout the same time it took me to pull out my dual transfer cases, rebuild them, and reinstall them last tuesday, but its a learning experienceso if u are still in the shop in texas, put the rear axle on jack stands and run it through the gears with the front tires chocked, and see if u can for sure tell its the rear driveline, and not a rear wheel bearing.
Started by toaster Rigs For Sale
Started by ohio Stolen Rigs and Theft!!
Started by valaris415 New Member Check-In!
Started by aruckusiheard New Member Check-In!
Started by Ruined Adventures Trail Reports, Events, and Gatherings
