KOH special!!! Ultra 4 4 seater Buggy
Started by rockin86runner, October 23, 2011, 09:11:42 PM
rockin86runner
posting for a friend
Putting up my rig for sale to fund a new one. This rig was built for the 2011 King of the Hammers race. Rig is a very good mix of go fast and rock crawling. The split times show it winning both a fast desert section over all as well as a tough rock section at hammers last year. 42nd place finish was do to a lack of test and tune time before the race. We rolled this car off the chassis table and headed to KOH with less than 100 miles of time on it. Over the last 8 months I have worked all the bugs out, and now enjoy anything from family trips at fordyce to competing in ultra 4 races. This is a do all rig with nothing spared.
Chassis: 1 3/4", 1 1/2", DOM. Front engine, ls based, 4 seater.
Engine: 2004 GM Lq4-9
Flat top pistons at time of vehicle build.
Stage 1 241 heads.
Beehive valve springs
Custom ground cam.
Fast intake
36lb injectors
aprox. 500hp at crank
Transmission: TH400
32 sprag
Manual Valve body
2000rpm stall convertor
T-Case:
Atlas 3.0
Axles:
Front-
Ruff Stuff 9
Ried C's and knuckles
Yukon nodular iron center
Yukon Spool
Yukon 6.20 gears
CTM 40 spline 300m inner shafts
CTM 35 spline 300m outer shafts
CTM U-joints
CTM drive flanges
Rear-
Ruff Stuff 9
Yukon spool
Yukon 6.20 gears
CTM 40 spline 300m true full float axles
Ruff Stuff racing aluminum hubs
Ruff Stuff 40 spline drive flanges
Ruff Stuff spindles
Full upper and rear truss
Suspension:
Front-
Bilstein 2.0 17" coilovers
Bilstein 4 tube 17" bypass shocks
Bilstein 4" air bumps
Double triangulated 4 link
Heretic Fab heat treated chromo links
Aurora 1 ¼" heims upper and lower
Currie Anti-rock sway bar
F911 hardware
Rear-
Trailing arms, w/ aurora uniball and heims, whobble stoppers. 21" travel
F911 hardware
Steering:
Howe double ended ram
Howe load reactive orbital
Howe Trophy Truck steering cooler
Howe Trophy Truck p.s. pump
Fuel system:
32 gal. two layer fuel cell
Dual bosch internal fuel pumps w/check valves
Pumps operate on two separate switches
Flow through fuel rails
36lb injectors
External fuel regulator with pressure gauge
Fuel shut off valves "not cheap home depot junk"
Fire system:
Two external fire extinguishers
One D.J safety fire bottle W/remote handle
Cooling:
Griffin Radiator W/ two spall fans
Griffin large fluid cooler for trans W/ spall fan
Howe Trophy truck inline p.s. cooler
Seats:
Prp comp high backs w/ pockets and water system
Prp suspension bench 42" wide.
D.J Safety 5 point haresses
Wheels:
5 Raceline monsters
5 39" krt-b's
Brakes:
Wilwood 4 piston fixed calipers
Wilwood dual masters
Wilwood brake pedal with balance bar
Drive shafts:
JE Reel rear shaft with cv at tcase
JE Reel front two piece
W/spares
Interior:
Auto meter gauges
Hurst modified ¼ stick shifter
12 volt guy switch panel
Rugged Radio com system
Recovery:
Warn rc winch
Custom Splice winch rope
Inside winch control on switch panel
Sure I am missing something, so feel free to ask.
Price:
35,000 ready to go
42,000 race preped and pit support at KOH 2012. This does not include a spot into the race. If interested give me a call and we can work out details.
Joe 530-277-7874
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
:usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
rockin86runner
rockin86runner
