Author Topic: Aussie locker inner spacers required ?  (Read 1847 times)
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« on: Oct 14, 2011, 06:20:32 PM »
I traded for a 4 cyl aussie locker and its missing the inner spacers.  The guy I got it off of says he installed it without them.  Here is a pic with the spacers im talking bout circled in red.
Did older aussies not come with these ?
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: Aussie locker inner spacers required ?
« Reply #1 on: Oct 14, 2011, 07:39:40 PM »
? I installed mine when i put it in.  I would imagine they are there for a reason. why didn't you get them with the locker?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #2 on: Oct 15, 2011, 10:04:03 AM »
I'm looking at the manual I got with mine. (14 pages) It's supposed to have those spacers installed. I don't know what would happen without them. What happened to the ones that come with your locker? I would try to get them. Call TorqMasters and talk to their tech people.
These lockers don't just slip in place and go. Some cases have to be ground or filed so it will fit. There are clearances to check also. That may be what the spacers are for?
Looking at the manual, I really don't know exactly what they do or how critical they are. You might be OK running without them? Your call.
The side gears spline to the axles with thrust washers maintaining end play. The cam gears Spline to the side gears on one side and locate on the pinion shaft on the other with pins and springs between both sides. Not sure what those spacers actually do.
If I got it for free or REAL cheap, I would try. IF it was a cheap diff I didn't mind grenading if I was wrong.
Let us know what you end up doing.
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #3 on: Oct 15, 2011, 10:18:18 AM »
I believe those spacers are there to keep the alignment between the side cogs and inner cogs. Without them it would seem the inners could fall and come out of alignment with the side gears when they pop open when rounding a corner. I think I would want them in there. Maybe that's why the guy sold it because he left those out and it wasn't working the way it should have.  :dunno:
2manytoys
  • Male Posts: 583
« Reply #4 on: Oct 15, 2011, 02:42:08 PM »
fordh8r, you may be right about that. The pinion shaft isn't realy going to keep anything in perfect alignment. Good call. Best bet is to call the tech dept and see if spacers are available.
crazykooter [OP]
  • Male Posts: 1,418
« Reply #5 on: Oct 16, 2011, 11:17:32 AM »
Ya ford I have installed an aussie before and it had those spacers.  I was installing the locker for a friend and it didnt have them so I told him it has to have them.
They keep the out gears pinned to the carrier.  Without them the outer gears are loose and I am was very sure without them it would break pins very easy.
Thanks for all the input guys.
Last post Jun 29, 2004, 12:07:41 AM
by Skinny_Pedal
Last post May 11, 2005, 11:32:44 PM
by TEXXX
Last post Jan 16, 2006, 08:28:30 AM
by mudaddict
Last post Mar 28, 2008, 04:28:36 PM
by RN37DD
Last post May 18, 2006, 10:32:37 PM
by heep70
