1st gen 22r Distributor
Started by Muddytazz, October 03, 2011, 04:41:46 PM
Muddytazz
Can someone get me a picture of their distributor mounted to the block?  I would like to see how much it is rotated in the mounting slot.  I'm beginning to think there is issues with mine.  Its fully rotated counter clockwise  :dunno:
Build it right or get off the trail
give me a few minutes to find the pic, but the vacuum advance should be near the top closest to you if looking at the motor from the front of the truck
Muddytazz
I'll see if I can find some light to take a pic of mine also
Muddytazz
Really crappy lighting, see if you can see what I'm talking about.
Muddytazz
In the top pic, the front hose goes to the dizzy and the back hose is blocked off with a bolt (thats how I bought the truck).
In the bottom pic, that is the dizzy timing adjuster slot.
Sparkplug
Yeh, it doesnt matter as long as runs good, but on all ive done, that bolt sits in the middle pretty much. Where you got it sitting should have the timing retarded
Muddytazz
Well its been that way ever since I bought the truck and its been running rougher and rougher lately
83 Crawler
mines the other way around the closet one to the grill goes to my carb base and the inside one is open, but i have propane dont know if that means anything, you still have the weber right??
Muddytazz
Yeah its still the weber for now
you probably have a stretching timing chain, but you can adjust the timing you'll just need to remove that bolt, remove the distributor cap and re-stab the distributor.
83 Crawler
it might be the weber going to :pokinit:,
Muddytazz
weber actually runs decent, just won't pass smog so I know thats not the issue
83 Crawler
time for propane!!!!! haha jk but my truck runs so much smoother and better with the kit,
Muddytazz
Will go FI before propane.  I still wanna run my truck street legal
83 Crawler
i still drive mine, drove it all the way to browns and wheeled all day and drove home
Muddytazz
Yeah, but I want to rereg mine at my place legal like and not at someone elses place out of smog zone.  They are cracking down on that.
83 Crawler
ya i get a tax right off for having a clean vehicle and mines registered at my house, deq is just the same
fordh8r
  Don't know if you've checked this or not...but my Mechanical advance was sticking real bad on my distributor recently and I took apart the distributor to clean and lube the shaft and weights. It was pretty gummed up and hard to turn by hand even. My idle was inconsistent and it was strange how sometimes the truck would run better at times than others and more notably when I was pulling a hill. It never seemed to run rough as you say with yours but it didn't seem to be running quite right. Now with the weights free and easily moveable by hand it runs real smooth now and my timing is where it should be now that the weights aren't stuck in an advanced position and it idles great too!  :twocents: :beerchug:
Muddytazz
I'm thinking I might just throw a timing set on there for the hell of it and clean other things up.  The motor has 187K on the ticker and I have no knowledge of what the previous owner has done or not done.
83 Crawler
get metal timing chain guides its like 65 bucks for the whole kit a discount import! comes with chain and all that good stuff
Muddytazz
83 Crawler
o really? damn wish i knew that when i did mine, o well
Muddytazz
Quote from: 79coyotefrg on October 03, 2011, 08:24:16 PM
In this picture here the Manifold vacuum connection is connected here.  I do not have that connected, mine is located where that brass plug is but just has a hose looped to the other side.
http://i266.photobucket.com/albums/ii252/muddtyazz/1983%20Toyota/1004111121.jpg
If you look in the upperish left corner of the pic where that small plug is, can I remove that plug and move that diaphram deal over there and just remove that bigger fitting and just plug it?
