Question for any Mig Welder techies out there?
Started by Seeds, September 26, 2011, 09:05:26 PM
Seeds
I have a Hobart 187 handler that will not start an arc on the highest heat setting. It will weld just fine throughout all other settings. The weird part is it feeds wire and gas flows just no arc. There is really no other issue. I can flip it to 6 and it welds fine. swithch it to 7 and no arc, back to 6 and its fine. Called the tech department and they basically told me that that is pretty much impossible because if the wire is feeding than there is power to create an arc. It would be more believable if there was no arc at all.
Anyone have this issue? Or an idea?
BTW it has been this way since as far as I have owned it, I just never went to its highest heat until I did my steering box mount about 4 years ago.
Romans 12:2
junya92toy
Seeds
Quote from: junya92toy on September 27, 2011, 05:08:54 PM
That "tap" is not making contact.
Does that explain why it is just happening on one setting? I don't get why this would be an isolated thing and not throughout all the settings if there was no contact being made.
Not familiar with "tap" contact
Romans 12:2
junya92toy
Tapped means its setup with only 4-7 different volts you can select. Its just a switch, each one has its own contact.
Seeds
I'll try to take a look at the contacts next time. Ill let your know. Thanks for the input
Romans 12:2
brainlessfool
I use one that does the same thing alot, butt if I wiggle the salector a bit it will work.
have you triyed shacking the switch? a good kick?
Seeds
Romans 12:2
