Author Topic: 22r to 22re swap writeup  (Read 46913 times)
TURBO
  • Turbo Extremist
  • Turtle Points: 65475
  • Male Posts: 706
  • Capt. Insaino shows no mercy
Re: 22r to 22re swap writeup
« Reply #30 on: Oct 12, 2011, 08:29:55 AM »
and if you want your temp guage and fuel guage to work, you'll need the guage cluster from the 22re truck also.
not true, only if you use the EFI tank, (which i recommend)... that way the pump is in the tank.
but you can* use the carbed tank with an inline pump, thus keeping your factory style dash (if you are that fond of it)
*had issues with it starting, because i believe the pump we used has no check valve, so either we need to install a check valve between the pump and tank or use a different pump.
also check out http://board.marlincrawler.com/index.php?topic=35701.240 ... may be of use
***just found out this is a 2nd gen carbed to 2nd gen EFI swap, not a 1st gen carb to 2nd gen EFI (which i have done 2wice)***
        carry on...
« Last Edit: Oct 12, 2011, 08:43:36 AM by TURBO »
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
« Reply #31 on: Oct 12, 2011, 08:42:28 AM »
This still doesn't fix the probelm with the temp guage.  Different resistance in the clusters for the temp guage between the 22r and re.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
TURBO
  • Turbo Extremist
  • Male Posts: 706
« Reply #32 on: Oct 12, 2011, 08:47:19 AM »
True, but if you still have the sender for the original carbed gauge, install that into the EFI lower intake plenum and operate the gauge that way, the two plugs in the front are a temp sender and a temp switch for the computer, they are separate, non-related circuits.
if i remember corectly...
I AM :screwy:!!!
TURBO
  • Turbo Extremist
  • Male Posts: 706
« Reply #33 on: Oct 12, 2011, 08:57:38 AM »
by the way i REALLY like this thread, wish i would have done a better job with Caboose's Write up...
now i want to do a FULL write up like this for 1st to 2nd gen, and 1st to 3rd gen EFI swaps, DAMN!  :slap:
I AM :screwy:!!!
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #34 on: Oct 12, 2011, 09:09:49 AM »
that would be cool.  I wish someone had done one before I did mine 5 years ago.  great thread by the way.
ABD Motorsports
#4475
KK6QDW
87hillbillyoter [OP]
  • Turtle Points: -43
  • Male Posts: 1,066
  • Member since Mar '10
  • git er duuunnn!
« Reply #35 on: Oct 12, 2011, 07:26:30 PM »
weird, i used the efi tank, and it was empty. gauge read empty. put about 9 gallons in it and it read half :dunno:
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
  • Male Posts: 1,066
  • git er duuunnn!
« Reply #36 on: Oct 12, 2011, 07:39:19 PM »
i guess ill update this thread, i got nothing better to do
with the dash removed, pull the wiring harness.
then start putting the new one in.
drop er in thar
keep goin on the wiring
  • Male Posts: 1,066
  • git er duuunnn!
« Reply #37 on: Oct 12, 2011, 07:41:12 PM »
aand i got a question. these wires in the red, i cant figure out where they go? its on the same bit as the gauge cluster dimmer and clutch cancel button.
also, in the green ,there is a plug into a box that says something about RPMs on it, i cant remember exactly what it was. it also has a little knob that turns. the plug was on my old harness but not on the new. any ideas on this stuff?
also, with my lights on, the lights behind the heater controls dont come on unless the heater is on high. if the lights are off, they come on when its on high as well. i know pretty much nothing about wiring, so any help is awesome
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #38 on: Oct 12, 2011, 07:48:08 PM »
green circle i believe is what tells ac idle to kick up when on. Red I dunno off hand right now. Light issue sounds like a ground somewhere.
  • Male Posts: 1,066
  • git er duuunnn!
« Reply #39 on: Oct 13, 2011, 08:45:54 PM »
alright thanks man. anybody else know the red?
Last post Dec 03, 2004, 03:11:10 PM
by Mike D
Last post Mar 10, 2006, 05:46:12 PM
by 79coyotefrg
Last post Aug 09, 2006, 08:13:25 PM
by 79coyotefrg
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
Last post Mar 10, 2008, 12:25:48 AM
by Tallchevy
