Samurai Rock Crawler f/s
Started by TEXCRAWLER, September 04, 2011, 10:39:08 PM
TEXCRAWLER
Ok Here it is. Goin up for sale if someone can afford it. Sale price is $15,000  Clear title registrated in Texas. Its time for something bigger and bader. Crawl ratio 459.1   Looking for possible trades. 4 seater rock buggies w/HP, 4 door Toyota Tacoma truck w/cash
87' Samurai Buggy
95 Sidekick 1.6 16V
Wiring harness built by Trail Tough
Trail Tough unbreakable engine mounts
Doug Thorley Header
All serpentine pullies & belts
Petroworks aluminum fan
SOS adapter to adapt Sidekick bell housing to Toyota trany
Toyota W56 5 speed trany
Duel Toyota T-cases, Triple drilled flanges F&R
Marlin Crawler chromoly 4.7 Gears F&R
Marlin Crawler chromoly front output gear
Longfield chromoly rear output shaft
KC Day lighters
Duel red top batteries
Chevy alternator
Toyota long travel D-line front
Spicer D-line rear from Hi angle D-line
(5) 39" Super Swamper TSL's
15x10 weld on Beed locks
Summit 14" QA1 coils
Rancho 9000 shocks 99036
Front Axle:
Diamond axle front 3/8" thick steel
Longfield 30 spline inners
Trail Gear 6 Shooter knuckles Kingpins upgraded to Marlin Crawler 25MM (Very Strong)
Sky Manufacturing IFS Hub Conversion
5.29 spooled, V6, High Pinion, 3rd, triple drilled flange
Tacoma rear axle:
Trail Gear chromoly 30 spline inner axles
5.29 V6 Tacoma rear, spooled, triple drilled flanges
Rock diff. guard
Sky rear disk break setup
12,000 lb winch
PSC full hydro 2" double ended ram
Eaton orbital box
Trail Gear oversized reservoir / filter
PSC 4 gallon per. min. pump
4 link F&R 2"x1/4 wall DOM tubing
TG Creeper Joints @ all 16 points
Link brackets Trail Gear & Rough stuff specialties
Trail Tough tube front clip, tube doors, shock hoops, bad boy rock sliders
Trail Tough rear tub cap
Rock4xFabrication NCZ Full cage tied into frame.
Full Safari top and Best top wind jammer, complete stock full top if you want it.
17 Gallon fuel cell
Hi pressure fuel pump
CD player
2" wheel spacers on all 4 corners
Rock lights
Grant Steering wheel
5 piont harnesses
Extras:
Full set of doors
1 , V6 Tacoma 5.29 rear
1, V6 Toy 8" front
2 spare ecms
87' Samurai, Dimond-F, Tacoma-R, 5.29 F-detroit R-spool,6 Stud knukles, 4-link coils F&R, Duel Marlin chromoly 4.7 Toyota T-Case, 39.5 TSL's, 8000 lb winch, 6 piont cage, Full Hydro, Sidekick 1.6 16V, Thourly header, LongField 30 splines, 115" WB, crawlin @ 459:1
I could care less for turtle points.
TEXCRAWLER
TEXCRAWLER
#2
TEXCRAWLER
TEXCRAWLER
