Front D-shaft options
Started by wood, February 07, 2005, 10:03:48 PM
wood
I am fix'in to do an SAS on my 88 Runner. It has the V6 with auto. I will be installing a used set of the all-poo's front 4'' springs. (or what ever came in the 5.5" extreem lift kit for front springs)
Here are my two cheap options as I see them:
#1. Use a die grinder and clearance the stock front cv joint to take more angle and the use square tubing for the shaft
#2. Use just a standard u-joint at the case end and use square tubing for the shaft.
I don't care about vibrations on the street since This shaft will not see any speeds about 20mph. I know that running a dual case will make the angles better but I know there are some on this board running close to this lift with the autos. What is the better solution for me?
Thanks for the help
New project--1988 4Runner Currently stock, but not for long!
www.HCOR4x4.org
Single u-joint with square shaft.  Thats what Im running in my 90.  I did it a bit differently (of course) and I used 2x1/4" and 1 1/2x1/4".  The 2 1/2 for outer is pretty big and i wanted to have a lighter weight driveline that had a smaller diameter.
FatAzzRunner
Yep.  2nd the Square shaft.
Stronger than you will ever need and just plain works and its cheap.
I have dropped onto my front driveshaft from over 4 foot and in just nicks the paint.
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
KYOTA
I just built my spare square shaft - 2.5 x .250 and 2.0 x .250 heavy mofo, Whitey where'd ya get yours chromed? 8)
It was a joke mang!  Im all about the bling, you know that! :greengrin:
fuglytruck
square tube it    u will be alot happier
i just cut a guys 4x4 in half and he didnt even put up a fight.
