97 Dodge Cummins ECLB 4x4 5spd custom front suspension 8500$
Started by Bradtoyotas, August 29, 2011, 06:09:13 PM
Bradtoyotas
97 Dodge Cummins 12v extracab longbed... Manual 5 spd trans, 172k miles, a/c works excellent. Truck has been modified in the front to leaf springs and ford front axle. Axle is out of a 88 ford f-250 high pinion kingpin. No more ball joints, track bar, unit bearings to go out, & no more tires goin to trash from the factory front end. I also used ford powerstroke 4" leaf springs in the front new from tough country. This truck is bullet proof for the most part. Recently in the past few months I have gone thru and replaced windshield, front shocks, rear driveline ujoints, carrier bearing, and balanced rear shaft. Also went thru the transfercase and rebuilt it and put a Brandnew tail housing on. Truck has a custom flatbed my buddy built he built it to look different from everyone else's. Truck is mostly stock it has a AFE cold air intake and I pulled the fuel plate to give it a little power and I like it Rollin coal. KDP (killer dal pin) has been fixed. Interior is in great shape except headliner is not the rite one for the truck so it doesn't fit exactly rite. Exterior is decent front drivers fender is rough. Tires are about 75% except one is worn uneven from a chevy they were on before they need to be balanced if I have time I'll get them done. About the only two things the truck needs is the gears in the front axle to match the rear or the other way around. Front has 4.10s and rear has 3.54s, & the rear squats a little it could use a little more lift.......  I'm asking 8,500$
Tonka Toys
Bradtoyotas
Tonka Toys
87hillbillyoter
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
Bradtoyotas
Nice truck but that wouldn't quite be a fair trade.. I would have to prolly give you some cash...  :qtip:
Jk  but maybe if there was amount of cash involved. What's done to it?
Tonka Toys
87hillbillyoter
yea i figured, haha. not quite as much as i hoped, but its a work in progress. SAS'ed on 35s, welded rear, exhaust, bumper, lots of other little things.
*edit* just realized you were in utah. little far...
Bradtoyotas
Tonka Toys
TacoStewie
4THEWKN
