g52 shifter
Started by pc100, February 06, 2005, 06:34:09 PM
pc100
do the g52 shifter have a bushing  like the w56 or is there a way to take out some of the slack , its getting sloppy when shifting
Marlin has what you need cheap,    Nate
pc100
where is it at on his web site ????  thanks
Heavy Duty Shifter Seat
It's common for the factory shifter seat to wear, crumble and disintegrate over time. This often results in a sloppy or loose transmission shifter. The factory seat is soft so it can be squeezed into position. We took a different approach, and machined groves into the sides of our heavy duty seats. Instead of squeezing the seat into place, the groves on each side allow ours to rotate into position. This allows us to make our seat from stronger, longer lasting hardened urethane. Our new heavy duty seats will far out last the stock units and will reduce shifter slop. Please state year and model when ordering. Two different sizes, one sizes fits W56A and W56B models, the other fits all other 4wd applications. Heavy Duty Shifter Seat $8.49
Shifter Socket $4.51
bluetoy84
You might also want to check to see if the grooves in the side of your shifter are worn. If they are you can weld it up and file it back down. If you do that and put new bushings in it should be good as new. :thumbs:
pc100
thanks alot  for the info
