Diesel swaps..........guy with datsun at last years round up.....
Started by seabass, August 08, 2011, 06:50:01 PM
seabass
what motor was he running?
buddy thinks it was small, maybe cummins b3.3 or a yanmar?
anyone have leads on a 2lt toyota diesel?
I want a non efi setup
but will look at efi setups
motor alone or half cuts
2lt-te
1kz-te
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
seabass
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
46&2
Are you dead set on running a Toyota diesel? Why not go for the Mercedes OM617 and 4x4 Labs adapters.
seabass
not 100% but 99%
4x4 labs has always has a history of being slow to deliver if I remember right
they made the divorce toy case adapter but quit, same guys?
I'm slowly looking at all swaps, busy so I don't get to read as much as I want.
still need to get my rig ready for MCR + gota make a dozen panels for the raffle, + backed up on orders..........
time............give me some time :)
Quote from: 46&2 on August 10, 2011, 08:45:22 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
46&2
Quote from: seabass on August 10, 2011, 08:49:24 PM
not 100% but 99%
I'm not sure if they ever did divorse toyota case adapters. I don't seem to recall that but maybe they did. From my understanding they made a big batch of these adapters for the GMs and Toyotas and you should be able to call and order one right away. The Labs produces top quality products though, I plan to do the OM617/4x4 Labs swap in the future. Luke has sped things up over the years so that shouldn't be a problem. Either way, look forward to seeing what kind of diesel goodness you decide on.
seabass
is that the motor in the 300sd?
5cyl?
there is 1 swap on pirate, but guy built adapter himself, either different or he didn't know of an adapter?
Quote from: 46&2 on August 10, 2011, 09:43:31 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
seabass
looked into this
called 4x4 labs to buy there kit, left message..............
looking for a good running 300sd turbo diesel :)
this looks like the best diesel motor swap yet
my buddy said something about this a few weeks ago
4x4 labs is only a few hours away, didn't know that:)
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
85muder
Hey bro good luck on the swap. I'm looking into doing the same swap I'm just not sure if I like the vw diesel more. What made you go with the om617. Instead of vw or toyota. I've read the tread and at first you where going with toyota. Sorry for the dumb questions just and to get as much information on diesel swaps as possible. When you get everything for the swap are you going to do a build thread on the swap. And thanks again.
seabass
easy to get everything
only toy diesels I find now are all electrontc
efi 1kz-te
can't find a 2lt manual IP
added bonus is the toy diesels run $3,000 for a 2l-te & $4,000-6,000 1kz-te
300 td's whole cars $900-3,000
adapter around $625 with flywheel
+ more power
stock mb is around
300CD
MY 1981–1985 OM617.952 125 hp (93 kW) @ 4350 181 lb·ft (245 N·m) @ 2400
turn boost up to 20lbs & IP up for 145-175hp?
read no trouble till you hit 35psi
can make 250-300hp, but reading $1200 for IP work, bigger turbo, better exhaust & doesn't seem to be any off the shelf parts for getting out more power, do it yourself stuff
http://www.superturbodiesel.com/std/showthread.php?tid=1505
http://www.yotatech.com/f162/1st-gen-p-u-om617-951-a-225014/
http://www.youtube.com/watch?v=Nl3Hfw9OzB4&feature=autoplay&list=ULg5cVHhkFcUU&index=3&playnext=4
Quote from: 85muder on August 12, 2011, 07:14:42 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
85muder
Why do you not want a efi diesel I know the difference between the two but are the ip easier to work on or to get more power out of. And what year of the engine is best for the swap. Thanks for the information you just posted. Sorry for the dumb questions. Hey bro did u not like the vw or is it that the om617 just the better diesel.
seabass
simple, manual IP
1 wire
fuel shut off:)
Quote from: 85muder on August 12, 2011, 08:33:14 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
twistedtoy92
I've got a line on a handful of 2Lt diesels in the 2wd toys..... Guy has at least 5 of them so hopefully we snag them for cheap! :yupyup:
seabass
all I have read is the turbo 2 LT never was in the 2wd just 1L & 2L
hope they are turbo
Quote from: twistedtoy92 on August 13, 2011, 10:09:15 AM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
twistedtoy92
might just be the non turbo then... he has them locked up on his lot so hopefully one of these days we can get in and scope them all out. wouldnt be hard to slap turbo's on them though!
seabass
ya it would,lol
you can't just slap on a turbo, you need more FUEL so you need a turbo IP....:)
Quote from: twistedtoy92 on August 13, 2011, 10:20:35 AM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
twistedtoy92
yes I know I am a flat rate diesel/propane/gasoline mechanic..... more fuel is not hard to achieve. hardest part would be fabbing up the manifold.
seabass
cool,I might have questions on more fuel on the 617
you can find stock 2lt parts on
http://www.toyotadiesel.com/forums/
& ebay
Quote from: twistedtoy92 on August 13, 2011, 11:01:43 AM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
twistedtoy92
seabass
found a cool site for info on the om617
lots to read on hot rodding these
http://www.peachparts.com/shopforum/forumdisplay.php?f=100
my uncle is checking out 2 300Ds for me, guy next door to him has 2 sitting
so if there is a good one for $1500 or less I might grab that
most around here are $2,000 to $2,500 not bad for a running driving good cond car
2lte runs $2,500 for motor trans combo
Quote from: twistedtoy92 on August 14, 2011, 11:06:43 AM
sweet! thanks for the info
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
seabass
pic
447hp-check
super charger-check
turbo charger-check
intercooler-check
balz-check check check :driving: :driving: :driving:
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
twistedtoy92
seabass
Now I wana swap a OM617 in everything,lol
looks like I can do FREE mods to get 16psi boost, stock is 12
bump fuel & get 140-160 hp
stock 180ft tq goes to ???...enough I think
Quote from: twistedtoy92 on August 14, 2011, 11:19:42 AM
holy :pokinit:
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
85muder
Hey bro I've been doing some research on the cummins diesels have you thought of the b3.3 Ive read a couple of treads on ih8mud and seen a couple of guys swapping them into land cruisers. You can get them brand new or used. There not cheap but there good engines. There's adapters so you can use a few trans even Toyota trans.
seabass
I have looked into them
bit heavier
bit more $$, well maybe alot more
didn't see toy adapter, saw sae to GM
looked overall more trouble & $$
great motor though
Quote from: 85muder on August 14, 2011, 12:16:55 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
85muder
Sorry forgot that you said something about the b3.3 in your first post. How do you add links to post. So maybe I can post the links for you if you like. And the link to the adapters your need. Ones from phoenix castings and the other is from advance adapters. Sorry if u already know this.just trying to help. Since you've given me some good advice about diesel swaps.
85muder
I've read that after the sae to gm you use the advance adapter gm to toyota. You have to use the two. Are they expensive used? There about 200lbs less then the 4bt. And sorry if u already knew all this just trying to help. Like u help me out bro.
seabass
just copy & paste link
if you can't get that to work, email them to me & I'll post
[email protected]
post anything you want, want this to be a diesel info thread more then anything
might help people out.
I am reading a ton & the info is wide scattered over last 10 years
no 1 thread anywhere has had all the answers yet, maybe this one will someday:)
Quote from: 85muder on August 14, 2011, 12:25:34 PM
www.12voltguy.com
TTC 2010 Driver #50
92 4runner
46&2
Quote from: seabass on August 10, 2011, 09:48:42 PM
5cyl?
Sorry for the late reply.
The OM617 is a 3.0 L inline 5 cylinder found in the 300D/300SD. Has approximately 90 hp and around 180 ft lb, but those numbers seen to vary depending on the year you get it out of. That is a great site you found thanks for that link. The OM617 is definitely a killer swap and provides lots of tuning options. Luke has swapped them into several Landcruisers now and has been loving every one of them.
And yeah, 4x4 Labs is in Grass Valley about an hour up I80 from Sac. Lot of good info developing in this thread.  :thumbs:
Rocksnail
Give the guys at All engine exchange a call. Hes in Fresno CA. I havnt been in there in well over a year, But he always has some diesels in there.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
