22r engine mounts
Started by sjelite, August 05, 2011, 07:08:33 AM
sjelite
Yes this is a stupid newbie question,  :stopit: I have a 1982 with a 22r will a 1984-89 22r drop right in?
I was reading through some forums on another site and I ran across a guy who said the engine mounts were in different locations. I did not think this was the case so I want to check it out with some people first. I found a local complete 22r I want to swap out in my truck. And yes the donor motor is a 22r not an re
Thanks
sjelite
David
I'm not an expert on this but I do believe the blocks are the same as are the mounts. My 83' and my grandsons 85 have the same mount location on the blocks.
Just check the mount location on the donor engine, you should be good to go.
Jokeass-Wheelers
It should be the same I also have a 83 and I put a 91 4 cylynder motor in it and it fit just fine also in my buddy's 83 Toyota 4x4 and I put a 1985 22r motor in it just fit perfectly
11 Jokeass-wheelers 7
1985 Toyota 4runner 22re 4x4 5:29 38in tsl's
IF IT LOOKS LIKE A PIG SMELLS LIKE A PIG IT MIGHT BE A PIG
sjelite
Thanks for clearing this up guys!
If you were in the area Id buy you a beer!
Jokeass-Wheelers
sparkys83yota
Don't know if this is relavent but my buddy has even dropped a 1992 22 re into an 82 and had no issues with the mounts not lining up.
83 shorbed pickup. 22 re swap. Dual ultimates, l52hd tranny, 5 " marlin trailflex lift. Yukon 529. Grizzly in rear zip locker front. And a bunch of other stuff....
sjelite
Any of these engine swap vehicles registered and smoged in CA? Im trying to figure out if I will have to do the whole BAR certification BS and get a sticker. Also if its a 4runner motor will it disqualify the smog check since it is an "suv" motor in a truck?
Jokeass-Wheelers
If the motor is 1 year or newer then ya I'm sure u can go get it REF'd at butte college I'm sure a 4 runner wiring harness will work easily
